need mangetic sensor — Parallax Forums
edited 2000-03-13 17:53 in General Discussion
I want to mount a magnet on a wheel and have the stamp sense the magnet
passing by
I want to signal conditioning to be built in so that the stamp just needs to
look for hi or lo
whats is this called, who sells it, for how mauch
thanks
richard
    edited 2000-03-13 16:23
    A hall effect device will do the trick. You have to provide a bias voltage
    and may need some signal conditioning depending on the exact device you
    select. If the wheel turns slowly, you might be able to get away with a reed
    switch. This is like a relay operated by an external magnet. These are
    commonly used in alarm systems to detect when a door/window is open. Of
    course, they need some time to recover and like all physical switches may
    have bounce. So you'd want to debounce it in software and you couldn't
    measure anything too fast that way.
    Good luck,
    Al Williams
    AWC
    *Floating point math for the Stamp, PIC, SX, or any microcontroller at
    http://www.al-williams.com/awce
    > From: dakota [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=09anlI69LzUzh22RCUiKz_4xeHUPGigSdqemvzSmVogqjBwg5ZUHPy0XnAYbMUDL]umc@i...[/url
    > Sent: Monday, March 13, 2000 9:33 AM
    > To: basicstamps@egroups.com
    > Subject: [noparse][[/noparse]basicstamps] need mangetic sensor
    > passing by
    > just needs to
    > look for hi or lo
    > thanks
    > richard
    > -- 20 megs of disk space in your group's Document Vault
    > -- http://www.egroups.com/docvault/basicstamps/?m=1
    edited 2000-03-13 17:07
    I'm doing this also, and recommend the following, all from DigiKey: Part #
    9208B, 18-page book summarizing different Hall ICs and their
    characteristics, part # HE510-ND, pack of 10 small magnets, and part #
    DN6851A-ND, bi-pullup SIP Hall effect sensor.
    Dennis
    From: dakota [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=frqxe9RrTzox95UnwCZFscieDCawh9QYVBfLsVEoB3Hi8p-gTvz6GMMlLOXuZwa2hwg]umc@i...[/url
    Sent: Monday, March 13, 2000 7:33 AM
    passing by
    look for hi or lo
    thanks
    richard
    edited 2000-03-13 17:21
    Why not just mount a reed switch near where the magnet passes and let
    the Stamp look for a simple switch closure? That would be a high,
    wouldn't it?
    Bob Oldham
    > passing by
    > look for hi or lo
    > thanks
    > richard
    Look at Hall Effect Sensors they are small and work well with stamps
    > passing by
    > look for hi or lo
    > thanks
    > richard
