put command on the BS2SX---------help!
edited 2000-03-11 - 20:44:00 in Microcontrollers
I've recently posted additional examples on using the BS2SX and BS2e at
http://www.emesystems.com/BS2SX.htm#example
that is the same URL as Al mentioned, just redirected. Some day I'll get a
real ISP, as Compuserve goes down the tubes.
-- Tracy
Original message:
Al Williams wrote:
The BS2SX works a little different than that. You use the editor to prepare
completely different programs and load each one into a different slot. When
you issue a RUN 1 command, that jumps to the completely different program.
Depending on which editor you use this works a little different so read the
docs with the editor you downloaded.
The PAK-II's memory is independent of the program bank, so you won't have
any trouble there. Just be sure to put the PAK-II library in each bank, or
work out some scheme to call back into the bank that has the PAK-II library
(the first way is easier, but does waste more memory).
Read: http://www.al-williams.com/wd5gnr/bs2sx.htm
and: http://ourworld.compuserve.com/homepages/emesys/BS2SX.htm
and: http://www.phanderson.com/stamp/bs2sx.html
Al Williams
AWC
* NEW: PAK-VII Pulse Input Coprocessor at
http://www.al-williams.com/awce/pak7.htm
> From: owner-stamps@p...
> [noparse][[/noparse]mailto:owner-stamps@p...]On Behalf Of Steve Znavor
> Sent: Saturday, March 11, 2000 6:31 AM
> To: stamps@p...
> Subject: [noparse][[/noparse]STAMPS] put command on the BS2SX
help!
> On my bs2sx i ran out of eeprom space so dont i just simply type
> RUN 1 to go
> to the next program where i can take advantage of another 2k of space? I
> typed run 1 a little bit before i ran out of space and then
> continued with
> my code after the run 1 command and it still said out of eeprom
> space what
> am i doing wrong?
