Measuring 15-150 ohm resistances — Parallax Forums
RandomRandom Posts: 1
edited 2004-10-10 01:11 in Learn with BlocklyProp
First time using this forum thing. Looks pretty helpful.
I'm trying to use a BS2E to measure resistances in the 15-150 ohm range.· I've built the circuit from "what's a microcontroller" for evaluating different resistors, then did the one with the 10K pot.· I've went on to trying a 15-150 ohm resistor but can't get it to work for the lower 85% of the range (about 15-125).
Anybody know the formula for·rc time constant·in parallel circuit?··I've found a reference·to be a "pot" command that can be scaled but I don't think it applies to a Basic Stamp 2.· Perhaps some additional A to D device?
    edited 2004-10-09 16:27
    Yes, I think a 12-bit A2D would be a cleaner, more accurate way to go than using RCTIME -- no cap tolerance issues to corrupt your result.
    Jon Williams
    Dallas Office
  • Aristides AlvarezAristides Alvarez Posts: 486
    edited 2004-10-09 16:47
    You're right about POT. It's a BASIC Stamp 1 command.
    For the BASIC Stamp 2 family you have the RCTIME command, which can be useful in certain situations.
    All the equations and information you need to use this command can be found in the Help File that Jon did for the BASIC Stamp Editor (rightmost icon on the BS Editor's tool bar).
    There you'll find sample circuits and equations to adjust component values optimizing your readings.
    In the case the resolution of the RCTIME command is not enough for your application, I recommend you to try our Basic Analog and Digital book:
    http://www.parallax.com/detail.asp?product_id=28129
    (You can download it for free at that link).
    All this material could be easily applied to your BS2e because it has the same time unit than the BS2 (2 microseconds).
    Aristides Alvarez
    Education Manager
    aalvarez@parallax.com
    Parallax, Inc. www.parallax.com
    California, USA
  • BeanBean Posts: 8,129
    I think as a rule with RCTIME with lower the resistance the larger value cap you would want to use.
    Terry
