IRL 520 Driver — Parallax Forums
IRL 520 Driver
Photon ArtistPhoton Artist Posts: 18
edited 2004-08-30 16:36 in General Discussion
Thanks to all who provided info and help with my schematics for the IRL 520 Driver!!!
I have put together a driver board, designed with ExpressPCB.
Would someone mind taking a look at the board layout for any mistakes?
Also, the booard will be driving solenoids using 12 volts.· How do I figure out what value resistor to use to power my indivator leds from the same 12 volt supply line?
THanks again for the help.
Rus
  • NewzedNewzed Posts: 2,503
    edited 2004-08-23 15:05
    Looks like your board is all wrong.
    Pin 1 of the VR is Input, Pin 2 is ground and Pin 3 is output.· That's for a start.
    Use a 12 volt LED with a 220 ohm resistor.
    Sid Weaver
    Pluggable Serial Backpack
  • Photon ArtistPhoton Artist Posts: 18
    edited 2004-08-23 21:46
    Hey Sid,
    There are no VRs on the board.· The transistors are IRL520 Mosfets.· Pin1 is gate, Pin2 is drain, Pin3 is is Source.
    Rus
    edited 2004-08-23 22:08
    Sorry about that.· If I double click on them the screen tells me it is a TO-220, 7805.
    Sid
    edited 2004-08-23 22:28
    Newzed said...
    Sid
    No Biggie Sid.· The IRL520 wan't in the parts.· So I just used anything with a TO-220 Package.
    I really should go in and change that part number.
    Rus
  • KenMKenM Posts: 657
    edited 2004-08-24 04:01
    edited 2004-08-26 13:55
    I have made additional changes to the PCB for the IRL520 Driver Board.
    Rather than having to wire a stamp to it I have integrated the OEMBS2.
    I have also added an LM2940CT-12 voltage regulator (12vdc 1amp) to power both the stamp and the solenoids.· I added a 22pf Electrolytic Cap fromthe output to ground as suggested by the Vreg manufacturer spec sheets.· Should I also add a .47pf cap to the supply side of the Vreg? This will be powered by a wall wart.· The OEMBS2 has a regulator that would then regulate this down to the required 5volts.
    Do you foresee any problems designing the board this way?
    Should I stick with separate power supplies for the driver board and stamp?
    Attached is the PCB layout in ExpressPCB
    KenM said...
    Slightly modified pcb.
    Ken.
    See notes in the private message
    "My mind wanders...I'm just along for the ride!
    edited 2004-08-26 14:28
    If I remember correctly the Stamp on-board regulator will only handle about 50ma total.· Your regulator should be a 7805 if you want to supply 5VDC to the Vdd pin on the Stamp.
    Sid Weaver
    edited 2004-08-26 20:29
    Sid,
    I am supplying 12 volts to the Vss pin on the stamp and allowing the onboard stamp regulator to regulate it down to 5.
    Rus
  • nick bernardnick bernard Posts: 329
    edited 2004-08-28 00:25
    thats a bad idea.
    if you put a potential on the vss pin then you risk a reverse polarity situation.
    also you should take advantage of your board space and spread out you components.
    and lay out your components in a nice neat manner before you run your traces because you should make your end product look nice to random joes that dont know jack a/b pcbs. you can usually route your traces to suit any layout. i attached a petty example w/o traces...
    also, if your going with the proto service, put lots of silkscreen lables to make your design very user friendly
    rox on
    nick B
    edited 2004-08-28 01:47
    NIck,
    How would you recommend powering the stamp?·
    RUs
    nick bernard said...
    thats a bad idea.
    rox on
    nick B
    edited 2004-08-28 04:51
    vss = ground <> 12v
    vdd = +5v or Vin = 16 to 24v
    rox on
    nick B
    edited 2004-08-28 16:14
    Nick,
    Sometimes I'm jsut a moron.· I misspoke.
    For once I actually had it right.· On the Board Vin is connected to the external regulator 12+ output and Vss is to ground.
    Rus
    hehe
    just messin with ya dude
