#29143 Urgent — Parallax Forums
#29143 Urgent
verovero Posts: 3
edited 2004-08-14 15:45 in BASIC Stamp
Sorry to all of you! I don't want to hurt anybody. I'm a spanish student, and·I don't know how·I must·send the posts.
I can't see· the picture, is very little and I don't understand the connections. Could you send me an other one or write the connections?
Thank you!
Post Edited (vero) : 8/14/2004 4:54:55 PM GMT
    The HomeWork board doesn't have the AppMod connector required by the Audio Amplifier AppMod, so you're going to have to rig the connections yourself. Have a look at the schematic in the Audio Amp AppMod specs -- what you'll see is that you need to connect your FREQOUT/DTMFOUT (can be any pin you want since you're not using an AppMod header as on the BOE) pin to the P10 connection on the AppMod, and you'll have to bring Vin (6 to 12 volts) and Vss (ground) over as well.
    The attached graphic shows the pinout of the AppMod header.
    Jon Williams
    Dallas Office
    Post Edited (Jon Williams) : 8/14/2004 4:24:04 PM GMT
    850 x 856 - 79K
