get trouble — Parallax Forums
get trouble
ionion Posts: 101
edited 2004-08-10 15:52 in BASIC Stamp
Hello ,
I have trouble reading 2 words from the scratchpad ram with get.confused.gif
I declared two variable words V1 and V2
I managed to put on the scratchpad from 0 to 8 eight digits as follow:
0 1 2 3 4 5 6 7··· location on the scratchpad ram
1 2 3 4 5 6 7 8··· numbers at that location. I know they are there as i can see them·with debug when i enter them one by one.
I need to read now the V1 as =1234 and v2=5678
I used GET 0,Word V1 and
········ GET 5,Word V2,
but what i get is V1=0513 and V2=1541
What·am I doing wrong ?
Please help.
  • Bruce BatesBruce Bates Posts: 3,045
    edited 2004-08-10 08:41
    Ion -
    Posting the entire segment of code would probably be real helpful.
    Bruce Bates
  • ionion Posts: 101
    edited 2004-08-10 09:47
    Hi Bruce,
    Here is the code:
    KEYIN········ ·· VAR···· Byte
    CURSOR········ VAR···· Byte
    RESULT········ VAR···· Nib
    v1················ VAR··· ·Word
    v2················ VAR···· Word
    CURSOR=0
    INPUT_DATA:
    SERIN 14\2, 84,[noparse][[/noparse]keyin]
    IF KEYIN < $3A THEN RESULT= keyin-$30
    PUT cursor,result
    DEBUG DEC cursor," ",DEC result,CR
    CURSOR=CURSOR+1
    IF (CURSOR) = 8 THEN VERIFY
    GOTO INPUT_DATA
    VERIFY:
    GET 0, Word v1
    GET 3, Word v2
    DEBUG DEC v1," ",DEC v2,CR
    And here is the Debug window display
    0 1
    1 2
    2 3
    3 4
    4 5
    5 6
    6 7
    7 8
    513 1541
    Thanks for looking into my problem
    Ion
    edited 2004-08-10 12:39
    Words occupy two bytes each in the Scratpad (stored in binary format, low byte, then high byte). You're actually storing the stream of digits. You could either modify your input routine, or convert your stream with a routine like this:
    SP_to_Val:
    · mult = 1000
    · value = 0
    · FOR idx = 0 TO 3
    ··· READ (target + idx), temp
    ··· value = value + (temp * mult)
    ··· mult = mult / 10
    · NEXT
    · RETURN
    Note that this routine is a bit limited: it expects your values to be in four-digit chunks. I think it would be easier to modifiy the input routine. I don't know the keypad you're working with, but I think you could do something like this:
    Get_Number:
    · value = 0
    · DO
    ··· SERIN 14\2, 84, [noparse][[/noparse]keyIn]
    ··· IF (keyIn < $3A) THEN
    ····· value = value * 10 + (keyIn - $30)
    ··· ENDIF
    ··LOOP UNTIL (keyIn = XX)
    · RETURN
    This will take a key, convert it from ASCII to a digit if valid, then add it to the value. Note that the value is shifted left one digit (x 10) for each new valid digit. A robust routine would also allow a backspace key (simply divide the current value by 10 if backspace hit). The routine will accept digits until some terminater key (XX) is pressed.
    Jon Williams
    Dallas Office
  • ionion Posts: 101
    edited 2004-08-10 12:55
    Thank you very much Jon.
    It does works as expected. I will practice more with the rest of the code to see how it will interact and if i·have an other question I will postit.
    Thank again
    ion
  • ionion Posts: 101
    edited 2004-08-10 15:41
    Hello Jon,
    It works like a charm ( the second solution- is the one which i choose for testing)
    I can check my keyboard input against a stored password on an externall EEprom, and do what i want if password is wrong or good.
    Here is the test code:
    MASTLO········ VAR···· Word
    MASTHI········ VAR···· Word
    cursor········ VAR···· Byte
    value········· VAR···· Word
    keyin········· VAR···· Word
    I2CIN 0,$A1, 1616,[noparse][[/noparse]DEC4 MASTHI,DEC4 MASTLO ]·· ' stored value is 1234 and 5678
    Get_Number:
    cursor=1
    first:
    · value = 0
    · DO
    ··· ENDIF
    ··· DEBUG DEC value,CR
    ··· cursor=cursor+1
    · IF cursor=5 THEN check1
    · IF cursor=9 THEN check2
    · LOOP
    GOTO get_number
    check1:· IF (value=MASTHI) THEN first
    ········ DEBUG "Try again. Wrong password",CR
    GOTO get_number
    check2:· IF (value=MASTlo) THEN
    ··········· GOTO fin
    ········ ENDIF
    ······ GOTO get_number
    fin:
    DEBUG "Password OK",CR
    GOTO get_number
    Thanks again
    Ion
    I'm glad your code works now, but let me suggest that it's a tad disorderly and I think will become problematic as your program grows. Since you're always accepting a 4-digit number, you could create a subroutine that you can call cleanly, eliminating a lot of spaghetti GOTOs:
    Main:
    · FOR pw = 0 TO 1
    ··· LOOKUP pw, [noparse][[/noparse]MastHi, MastLo], testVal
    ····DO
    ····· GOSUB Get_Num
    ····· IF (value <> testVal) THEN
    ····· · DEBUG "Wrong password -- try again"
    ····· ELSE
    ······· EXIT·· ' terminate DO-LOOP
    ····· ENDIF
    ··· LOOP
    · NEXT
    Fin:
    · DEBUG "Password okay"
    · END
    Get_Num:
    · value = 0
    · idx = 0
    · DO
    ····· idx = idx + 1
    ··· ENDIF
    ··LOOP UNTIL (idx = 4)
    · RETURN
    Jon Williams
    Dallas Office
    Post Edited (Jon Williams) : 8/10/2004 3:58:53 PM GMT
