LCD Dot Matrix Displays and the BS — Parallax Forums
Mag748Mag748 Posts: 263
edited 2004-08-14 15:34 in General Discussion
Hello everyone.
I am very new to digital electronics and have a few questions.freaked.gif·
First of all, I know that it is very simple to connect a serial LCD display to the BASIC Stamp Microcontroller, but is it possible to use an LCD Dot matrix display, specifically one like the one found on any TI-83 Graphing calculator?
If the answer to the above question was true than
idea.gif·OK, since you can, I have a TI-83 Plus SE graphing calculator that has a functional LCD screen, but the actual calc itself does not work anymore. The LCD module is connected to the calc with a 17 wire ribbon cable. I have had no luck finding a schematic or any other reference that will tell me what those wires are or if they can be used with any other interface. Is there any way to interface the LCD dot matrix screen to the BASIC Stamp?
else
mad.gif·Oh well, nevermind then.
Thank you very much for your input,
Marcus
P.S. Best veiwed on a BLACK background
I do not own any type of Basic Stamp at the moment.
110145154154157040167157162154144041040145156143157144145144040151156040047157143164141154047
  • Mag748Mag748 Posts: 263
    edited 2004-08-13 23:11
    maybe this is in the wrong topic. thats why not a single person is answering.
    edited 2004-08-14 01:18
    Your questions would be easier to answer if you made them easy to read... yellow text on a white background is tough on the eyes.
    Controlling a dot matrix LCD is no trivial task, and probably not the best use of the BASIC Stamp -- a dedicated controller (with serial interface) is a more efficient solution. SEETRON (www.seetron.com) makes graphic LCDs that work well with the BASIC Stamp.
    Jon Williams
    Dallas Office
    edited 2004-08-14 04:03
    well, fortunately i do have a black backgroud, which makes this text very easy to read. sorry for the people who have other color backgrounds. in the future i will take that into acount.
  • Jim EwaldJim Ewald Posts: 733
    Maybe we need a color pallet leveler. Something that takes the background color into consideration and adjusts the foreground color to provide some appropriate level of contrast. Ok, maybe it's way down there on the list of things to think about.
    Jim
    Parallax IT Dept.
