LTC1298 12-bit A/D converter DIP — Parallax Forums
yzcheyzche Posts: 35
edited 2004-08-07 16:05 in BASIC Stamp
I try to use ·LTC1298 12-bit A/D converter DIP and here are my outputs.
channel 0: 109
channel 1: 186
channel 0: 104
channel 1: 72
channel 0: 100
channel 1: 117
channel 0: 99
channel 1: 112
channel 0: 101
channel 1: 111
channel 0: 103
channel 1: 108
channel 0: 103
channel 1: 155
only problem is that I did not put any input voltage for converter to convert. I thought each channel should returns 0 when there is no input voltage. I attached a picture of my bread board, I might have wrong wiring.
352 x 288 - 31K
  • BeanBean Posts: 8,129
    edited 2004-08-06 18:19
    If the input is floating (not connect to anything) then it is reasonable for the values to change.
    Connect the input to ground if you want zero's.
    Terry
  • yzcheyzche Posts: 35
    edited 2004-08-06 19:10
    I connect one channel to the ground. outputs are
    channel 0: 0
    channel 1: 1
    channel 1: 0
    channel 0: 0
    channel 1: 1
    channel 0: 0
    channel 1: 1
    I don't understand why both channels are affected. I thought each channel is independent.
  • KenMKenM Posts: 657
    edited 2004-08-07 03:19
    Post your entire program. You have to tell the LTC1298 to do single channels or run in differential mode.
    Do you know what mode you are running in?
  • Tracy AllenTracy Allen Posts: 6,656
    edited 2004-08-07 05:13
    You have to realize that the inputs of the LTC1298 are very high impedance and the tiniest bit of leakage or capacitance between pins can have a dramatic effect on the reading. What you see is typical of analog to digital converters of this type. When you ground one pin, there are tiny leakage currents (picoamperes down to femtoamperes) between the pins and within the silicon of the chip itself. That draws the second, unconnected pin toward nearly the same reading. If you have the LTC1298 plugged into one of those white prototyping boards, there is a huge capacitance (~100pf) between the two input pins, so the effect is practically instantaneous.
    If you leave one of the inputs floating and hook up a wire and a piece of aluminum foil suspended on it, you can have fun watching the reading change as you wave your hand near the foil "capacitor" plate. Your hand is the other "plate" in relation to the static electric field that exists in your space. (Don't touch the plate if you have been shuffling across the carpet!--that static flash might well burn out the input channel of the LTC1298!!!!!)
    Now, if you attach the second input to a solid voltage, say 1.5 volts, you should get a good reading. The low impedance of your voltage source dominates the leakage currents and the effects of coupling capacitance, which are very (usually!) very small.
    The same thing applies to the input pins of the BASIC Stamp itself. If you leave all the pins as inputs, and then connect one of them to +5 volts, you may well observe that that all of them, the neighboring pins especially, will also read high. Here is the fun program:
    DO : DEBUG BIN16 INS, CR : LOOP
    If you connect one pin to Vss instead, then all the neighboring pins will read low, at least for a while, until some other influence causes them to drift away. The effect is especially strong on those white plug-in breadboards, because the capacitance between neighboring nodes is so high.
    -- Tracy
    Tracy Allen
    www.emesystems.com
    Thanks everybody. I got it!
