Programing BS2p — Parallax Forums
Programing BS2p
Lee SadeliLee Sadeli Posts: 29
edited 2004-08-08 13:25 in BASIC Stamp
I am trying to write a BS2p software to read data from a synch serial input from an 8-bit register 74LS166A, but it can't really·work. Any one can help, plz.
The problem is at CLK INH that requires 2 high pulse during reading·the 1st and 2nd bit of the 8 bit data.
Many thanks
    edited 2004-08-05 23:32
    I just had a [noparse][[/noparse]very quick] look at the data sheet, and from what I gather you should be able to do this:
    1. Tie the Clock Inhibit (CLK INH) line low, and the CLR line high -- you don't need to control these lines
    2. (with the BASIC Stamp) pull the SH/LD line low, then do a PUSLOUT on the clock line -- this will load the parallel inputs
    3. Use SHIFTIN to grab the data
    Sorry, I don't have a 74LS166A -- otherwise I'd write a snippet of code for you.
    Jon Williams
    Dallas Office
  • Lee SadeliLee Sadeli Posts: 29
    edited 2004-08-06 09:50
    Wow, amazing !·faster reply than 911 responses.
    Seems like·the prob.·is more complicated,
    CLK INH=hi activate LOAD and·READ
    of FIRST, whereas to read·2 - 8 bit need CLK INH to be low and reading start at next leading edge of CLK.
    Maybe I may need two SHIFTIN, 1st to read 1st Bit at setting CLK INH hi, then 2nd SHIFTIN to read 2-8 bit by sending PULSOUT and setting CLK INH low
    Attached is the pulse diagram for 74LS166A.·Thanks again
    edited 2004-08-06 13:18
    I don't think it's that complicated, but can't prove my theory until I have a part. I will stop by an electronics store today and see if they have the 74xx166. If yes, I will pick one up and write some code. It's too bad you don't have the 74LS165 instead, I've got lots of code for it.
    Jon Williams
    Dallas Office
    edited 2004-08-06 14:33
    Great ! Appreciate it very much. Hope it won't cause you too much trouble.
    edited 2004-08-06 15:03
    It's no trouble at all -- if the store has the part I will have code ready tonight or sometime tommorrow.
    Jon Williams
    Dallas Office
    edited 2004-08-07 15:32
    Well, you've probably already solved this by now ... but in the event you haven't, my suspicions were correct and the device is pretty easy to use (just a tad more complicated than the 74xx165, but just a tad).· Demo code is attached.
    Jon Williams
    Dallas Office
    Post Edited (Jon Williams) : 8/7/2004 11:29:30 PM GMT
    edited 2004-08-08 07:47
    Many thanks, will try and let you know the outcome.
    I'll let you know the outcome now ... it works! In fact, it took far longer to wire up the 74LS166 circuit an on NX-1000 board than it did to get the code going.
    Jon Williams
    Dallas Office
