High Speed Square Wave Pulse Output (20kHz) — Parallax Forums
larsiflarsif Posts: 1
edited 2004-07-29 22:13 in BASIC Stamp
I have a BS2 and I need to provide a square wave 0 to 5 volt square wave to drive a stepping motor drive. Not a driver chip, but a complete drive that requires a 0 to 5 volt square wave. I need the high frequency output pulse train to drive the motor above 2400 rpm.
Has anyone developed a circuit for this type of application. I have used the FREQOUT and PULSOUT commands with no luck in reaching my top speed of 20kHz. I used the FREQOUT with a Schmitt Trigger but because the FREQOUT is generated via a·PWM the drive did not run in sink with the frequency. Any ideas?
Larry·
  • AlWilliamsAWCAlWilliamsAWC Posts: 135
    What varies about the pulse? Duration? Duty cycle?·Is 20kHz just the maximum you need? The PAK-VIII is very versatile and could do this since it has a minimum period of 10uS. However, depending on what you want to vary, you may or may not get sufficient resolution.
    Al Williams
    AWC
    * Kits! http://www.awce.com/kits.htm
