Digital QTI Output — Parallax Forums
Digital QTI Output
The QTI sensor documentation (posted below) says that it can provide a digital output. How would this be accomplished? Would I have to use the A/D converter on the Propeller board? In the example provided in the documentation (although it uses BASIC instead of C) it looks as though it takes a reading straight from the pin, but the board is a Mini-SUMO.
  • In the spin examples look at the RC time, and re write the Bs2 example
  • The qti sensor is 5v, don't know how well it works on 3.3 v, but you could use a transistor to turn on the led, I don't have one to fiddle with it
