P2 Floating Math with Power function — Parallax Forums
jcfjrjcfjr Posts: 74
edited 2021-04-15 20:37 in Propeller 2
I have found a couple floating point math objects for the P2, but none of them contain the Power function. The attached object from Total Spectrum contains a power function, but it is commented out as under development. It appears the Catalina plugin contains a power function, but I don't know how to use the plugin in Spin. Does anyone have a floating point math object that has the power function for the P2? I only need trunc, abs, add, sub, mul, div, and power. I have found solutions (with this groups help) for all the other PASM routines I was using with my application on the P1 , except for this last hurdle of calculating my swr using the power function. Once I get past this, I think I will be in a position to start moving my application from a P1(Spin) to a P2(Spin2) with the new solutions.
  • There's a whole thread on this subject, with 3 different implementations posted in the first message. As noted there, BinFloat is pretty complete and includes an FPow() function.
    The BinFloat object is also in the github OBEX.
  • I was under the impression that the BinFloat only handled integer exponents. I need to solve 10 to the power of x, where 0<x<1, i.e. 10 to the power of .312 , so I thought that BinFloat wouldn,t work. Am I wrong?
    What gave you that impression? Is there something misleading in the documentation or comments? The BinFloat FPow() function accepts any arguments.
  • jcfjrjcfjr Posts: 74
    edited 2021-04-20 18:34
    No, the documentation is not misleading if you read ALL of it(my bad), I had not taken a close look at BinFloat, I was focused on DecFloat. Now that I have downloaded your complete zip file from Mar22, and am using the BinFloat object, I am getting the right answers that I was looking for, thanks for pointing me in the right direction. I would like to understand your use of the Send command, because I cannot get anything out of the testbin program. I thought it was simply opening a PST window in the Propeller Tool which work off the same assigned pins, but that doesn't work. How do I see the text the Send statements are sending out through the serial smart pins?
  • Send does send data to the regular serial ports, at least as set up in my demos (with send := @ser.tx, after ser is set up at 230400 baud).
    I'm used to running code with loadp2, which has a built in terminal and hence doesn't need any delay. If you're using a separate terminal program you'll probably need to insert a "waitms(2000)" or something similar into the main Spin function before the ser.start() call, to give time for opening up the new terminal.
