Shop Learn
PASM Question for register Indirect — Parallax Forums
SuracSurac Posts: 153
edited 2021-04-02 15:44 in Propeller 2
given the following code that should print out the COG ram on serial port in PASM
serOutCog jmprel #+1
        .counter long 1
        mov .counter, #0
.loop
        call #serCRNL
        mov _serOutAddr_Arg0,.counter         'this will print the Address
        call #serOutAddr
        call #serSeperator
        mov _serOutLong_Arg0,.counter        'Wrong. How to copy the value IN the COG register number .counter??
        call #serOutLong
        add .counter,#1
        cmp .counter,#$1FF wc
 IF_C   jmp #.loop
 ret
how to mov the value inside Memory location .counter to _serOutLong_Arg0 ?
_serOutLong_Arg0 is defined as long 1 in the COG
  • Use the ALTx instructions. The documentation has the details.
    alts .counter
    mov _serOutLong_Arg0,0-0
  • SuracSurac Posts: 153
    This works only with cog ram, right?
    Tor LUT and HUB there are other ways, right?
    Addresses will warp if i go over $1FF, right?
    Yes, ALTx is for cog RAM only.
    For LUT you use RDLUT/WRLUT, for hub you use all the other RD/WR instructions (and WMLONG)
    yes
    Thank you very much
  • AribaAriba Posts: 2,456
    @Wuerfel_21 said:
    yes
    Does this mean that the P2 has a built in Warp drive and you can activate it if you access the cogram behind $1FF ?
  • @Ariba said:
    @Wuerfel_21 said:
    yes
    yes
  • TonyB_TonyB_ Posts: 1,678
    @Wuerfel_21 said:
    @Ariba said:
    @Wuerfel_21 said:
    yes
    yes
    But only after this instruction:
    ENGAGE
