Shop Learn
Max7219 display - help — Parallax Forums
VonSzarvasVonSzarvas Posts: 2,348
edited 2021-04-06 04:06 in General Discussion
We have a customer that asked about using the Max7219 display with the Parallax Propeller P1.
When the unit is turned on all 64 leds lock on to max brightness .. no codes sent to the unit dislodge this .. the only way to reset it is to disconnect vcc
I don't one of these modules yet.... is there anyone that has tried this module ?
Any advice on how it should behave ?
Thank you !!
Edit: microcontroller was originally stated as P2, whereas the customer is working with the P1.
  • JonnyMacJonnyMac Posts: 7,535
    In my experience the MAX7219 is pretty well behaved. They could try a pull-up on the CS pin to keep things quiet. Should also check initialization code, because proper coms to the device should allow the display to be cleared. I've attached my simple P2 object that was used in the online class I did a couple months ago.
  • @JonnyMac .. I had done the pull up on the cs pin with no success .. I'm still a P1 spin programmer so your P2 object example was a bit of a challenge .. but I got it ..
    I had not used the initializing led test " turn on all the leds " code .. when you do use that code you follow it with " turn them off " .. I added that to my initializing
    code and all seems to be working now .. THANK YOU VERY MUCH FOR YOUR TIME .. stopwatch in Minnesota
    I'm glad you got it working. I do have a P1 version of that driver if you want it.
  • Thanks Jon- and apologies for having assumed the wrong uC.
    P1 code... yes please! That would be great. I should update this thread title appropriately!
