Thermally stable solder paste
Rayman
Just noticed this stuff on Digikey:
https://www.digikey.com/en/products/detail/chip-quik-inc/TS391AX250/7802227
Looks like it lasts longer than usual and doesn't need refrigeration.
Is this new? Must be I think...
Assuming there aren't any other magic ingredients, I can attest to its long life, i have a 500g pot of multicore that lasted about a decade before becoming marginally too dry. You could still use it at a pinch, if you had to
IIRC its' useby was 2012. It's easy to add a little 100% isopropyl alcohol to a scooped out blob and mix and it works just fine
