Anyone here have experience using the LaserPING connected to a Raspberry Pi? I searched the forum but didn't find much.
I popped the device in a breadboard and wired my UART pins to the sig line and provided 3.3v and gnd to the appropriate places. I want to use serial comms for this so I applied a dab of solder to short the DBG and SCK pads.
I haven't done serial comms before but I have a couple of test scripts that at least show I can read and write on loopback. I apply power to the LaserPING and set up my reading loop, but I get nothing but blanks.
Here's the code of my loop:
import time, serial
ser = serial.Serial('/dev/ttyAMA0',9600, timeout=1)
try:
while True:
data = ser.readline()
print (data)
time.sleep(1)
except:
print ("I take exception to that!")
finally:
ser.close()
I can confirm 3.3v is available to the VIN with an LED. My reading loop does pick up if I write to the serial from another script, so I know it's hooked up.
Any ideas of what questions I need to ask here?
Thanks!
I tried this code and it seems to work. I had to use ttyS0 for my Pi 3B
