PropTool shows wrong clock settings — Parallax Forums
PropTool 2.4.1 shows wrong clock settings in Object Info view and ignores _xtlfreq setting. It shows always "Clock Mode=XTAL3 + PLL1X" and "XIN Freq=Clock Freq" if a _clkfreq is provided.
The same code using PNut shows the correct clock setting and "Clock Mode=7pF XTAL + PLL".
I didn't check the generated code for clock setting if using PropTool. The code is running fine if loaded into the propeller.
981 x 817 - 125K
591 x 799 - 114K
