Video Interface — Parallax Forums
Video Interface
I am creating an HDMI port for the P2 edge board. Similar to the parallax one.
Do the traces all need to be the same length ?
  • roglohrogloh Posts: 5,157
    edited 2020-11-15 01:48
    Ideally yes, but it's more important to try to have the two wires in each pair see the same impedance to maintain signal integrity. In practice for the low resolutions generated by the P2 such as VGA, it tolerates a decent amount of skew. For example, the P2-EVAL wasn't length matched anywhere but it's close enough to still work well. I think in the early days Chip was even able to get something working with some simple flying leads.
    The DVI spec mentions this about the allowable skew at the receiver:
    Speed of light in a PCB at ~1.6x10^8 m/s means electrical signals travel about 16cm/ns. 0.4 x 1/252MHz would allow 1.6ns of skew or the time for signals to travel ~25cm. So that's a fair bit of trace length difference. Once you crank up the frequency for higher resolutions things begin to tighten more.
  • SaucySolitonSaucySoliton Posts: 487
    edited 2020-11-15 01:53
    I don't know if the traces on the P2 edge are all the same length. That needs to be checked.
    HDMI receivers likely have some ability to compensate for delays between the channels. In this experiment http://forums.parallax.com/discussion/comment/1463361/#Comment_1463361 I generated the clock signal from the smart pins. What was interesting was the clock phase didn't matter. It's not used for sampling the data, just as a frequency reference. Obviously, don't go out of your way to unbalance the lengths but at P2 data rates 1cm of trace is much less than 1 bit of data.
    I think it's more important that each differential pair be routed appropriately. The length of + and - traces should be the same. The spacing between them will affect the impedance. Although at the <320Mbps the P2 can operate at, none of this should be that critical.
    Edit: Thanks, @rogloh for finding the skew spec.
  • Greg we've found some monitors need that 5v signal on pin 18 in order to wake them up and display the video.
  • Nice, this should also work for the KISS board. For those who don't want to buy the full set of accessory boards it' good to have a cheaper second source.
  • So some monitors won't work with the Parallax Accessory Set. Is that going to get fixed? Is there a way to add the 5 Volts to pin 18 on the connector?
  • Yes you can solder a resistor from 5v at the female header, to the pad labelled '5v' which connects to pin 18 of the hdmi connector
    I've used a 1kohm resistor with success
  • 1k worked well for me too.
