Shop Learn
Basic Stamp 2 — Parallax Forums
Basic Stamp 2
Jack1234Jack1234 Posts: 6
edited 2020-11-14 00:10 in BASIC Stamp
Board of Education must be not working correctly anymore RCtime circuit works fine by itself pot can turn servo. Add the bicolor circuit in basic stamp won't work with RCtime circuit and then no result in the serial dialog box. It the board of education , finished ?
  • You really need to attach your source code to a message and post it for us to look at. Although your problem is probably due to a programming error, it's impossible to tell without looking at the program. Include in your message a description or picture of your wiring. Sometimes even a small change can cause the result to not work.
  • I will go back and check the circuit and work on the code alot more. Thanks Mike
