VGA - Chip's sample code — Parallax Forums
I was modifying the code to run on my new P2 board which uses the VGA on a 4 pin boundary instead of the usual 8 pin boundary.
Since VGA uses 5 pins being 4 pins (Hsync, B, G, R) plus Vsync and I wanted to use VHGBR in the top 5 of the 8 pin group, I decided to modify the grouping to support 4 pin grouping where the 5th pin (Vsync) was 1 pin lower than the 4pin group when the 4 pin group was odd.
While doing this (and it's working) I saw something unusual in the driver spin code section. When the cogstop call is issued, the VGA pasm cog is stopped and then a pinclear(av_base_pin_ addpins 4) is issued to clear the pins. However, the only cog setting these pins is the pasm cog and when it stops the pins are cleared down. The pins are not set/configured by the spin cog, so this pinclear will not do anything and indeed should not be there.
Am I missing something???
PUB stop()
'' Stop VGA driver cog
  if cog
    cogstop(cog-1)
  • Stopping a cog only clears DIRx and OUTx bits.
    Pinclear clears all the pin mode and control bits.
    ozpropdev wrote: »
    Can you clear those mode and control bits using a different cog?
  • Cluso99 wrote: »
    ozpropdev wrote: »
    Yes.
    The pin control/select bits can be change at any time by any cog.
  • I wonder what happens if two cogs try setting a smartpin mode on the same pin at the same instant?
    Is it just that one of them wins? Or does the smartpin get some garbage combination of both settings?
    I suspect based on what I recall Chip saying about how the mechanism works for talking to the smartpin stuff, that it's "one of them wins".
    edited 2020-11-03 08:12
    Roy Eltham wrote: »
    Yes, probably tied to the hub rotation like other stuff.
    But it could get mangled between one cog setting up wxpin and another jumping back in to set the wypin. But no real difference with two cogs outputting on the same pin and the results being ORed. You just gotta do it right.
  • IIRC from tests I ran a while back trying to set the same smartpin at exactly the same time from two cogs causes the data to be OR'ed together, no cog wins!
    Looking for my old test code now....
  • ozpropdev wrote: »
    Smartpin collision test - ozpropdev
    dat     org
                  loc       ptra,#@code1
                  coginit   #1,ptra
                  loc       ptra,#@code2
                  coginit   #2,ptra
                  waitx     ##600   'wait for cogs to load
                  cogatn    #$ff    'syncronized start wrpin
    loop          getct     pa      'fast,med and slow pulses
                  testb     pa,#22 wc
                  drvc      #16
                  testb     pa,#24 wc
                  drvc      #17
                  testb     pa,#26 wc
                  drvc      #18
                  testp     #19 wc  'read selected pin
                  drvc      #24     'shows slow rate (pin 18) ?
                  jmp       #loop
                  orgh      $400
                  org
    code1         waitatn
                  wrpin     ##%0110 << 28,#19   'medium rate -2 = pin 17
                  jmp       #$
                  org
    code2         waitatn
                  wrpin     ##%1101<< 28,#19  'inverted fast rate -3 = pin 16
                  jmp       #$
    The result is Pin #19 reads an inverted Pin #18 which is a combination (OR) of the two WRPIN instructions.
    I believe I have also experienced erratic behaviour trying to read a smartpin from two cogs at the same too.
    Of course this is a unusual case.
  • evanhevanh Posts: 15,187
    RQPIN, in place of RDPIN, is meant to work in parallel.
  • The issue I had with RxPIN was more to do with a WXPIN being issued on the same clock.
    The RxPIN instruction wins over WXPIN, WXPIN is lost.
    This is what happens when you break the rules. :)
    Ah, good info. I could incorporate that into the block diagram.
