P2 operating temperature range
I just saw on the P2 Eval board docs that the P2 is spec'd at only -40 to +85°C operation.
The P1 was spec'd from -55 to +125°C operation and we use it under those conditions sometimes.
If the P2 is clocked slowly can be it used over a wider temperature range ?
What fails in the cold / heat ?
The clock will be external so that is not an issue.
We use the propeller on a backplane that is inside of a temperature chamber.
We were hoping to create an updated system using the P2, but the temp range is going to be an issue.
Bean
  • cgraceycgracey Posts: 13,076
    edited 2020-10-14 - 01:01:24
    This is a question.
    We were assuming a 2.5 W dissipation with an internal junction temperature of 150 C.
    This was calculated considering the chip dissipating 2.5 W and running at 175 MHz, the package's Tja of 18 C / W, the PCB having a 9x9mm via array going down to 2 square inches of 2oz copper, with an ambient temperature of 85 C, poorest manufacturing conditions, and operating voltages down 5%.
    So, with an ambient temperature of 85 C, the chip mounted on a board as described above, dissipating 2.5 W, the internal junction temperature would climb to 150 C and the chip could operate at 175 MHz.
    The thing is, the power dissipation is WAY lower than expected, so this temperature rating is VERY conservative.
    I've been asking Wendy at ON if she could run some timing simulations at lower junction temperatures, but she hasn't gotten back to me, yet. When we get that data, we can curve fit it to come up with realistic numbers.
  • The self limiting frequency feature of the PLL seems like a good way to map the operating boundary of any given application.
  • Thanks Chip.
    If you can give me some idea about what the max clock would be at +125°C that we be helpful. No hurry, whenever Wendy gets back to you.
    Is there any issue at -55°C ?
    Bean
  • evanhevanh Posts: 9,956
    edited 2020-10-14 - 01:13:53
    Bean wrote: »
    Depends quite a lot on power draw by the software. Which can be mitigated by good heat sinking. If the die is at 125 then maybe 250 MHz, certainly 200 MHz easy.
    Just the usual mechanical stress damage from thermal cycling.
