Looking for a New Solution to Existing SPIN to SPIN2 code — Parallax Forums
The following method worked fine in SPIN:
PUB limitRange(value, lowest, highest)
value #>= lowest
value <#= highest
RETURN value
SPIN2 doesn't like the 'RETURN value'.
PUB limitRange(value, lowest, highest) : value
value #>= lowest
value <#= highest
The above errors to: Expected a unique result name
    This should work
    PUB limitRange(value, lowest, highest):result
    result := value
    result #>= lowest
    result <#= highest
  • JonnyMacJonnyMac Posts: 8,927
    edited 2020-10-12 03:39
    I tested this variant -- it works as you wish:
    pub limit_range(value, lo, hi) : constrained
      return lo #> value <# hi
    This code is giving you a problem because you are using "value" as a parameter name and the name of the return variable.
      value #>= lowest
      value <#= highest
