Shop Learn
Small RISC-V chips — Parallax Forums
Small RISC-V chips
Peter JakackiPeter Jakacki Posts: 10,166
edited 2020-10-10 00:22 in Microcontrollers
I've got a few of these Sipeed Longan Nano - RISC-V GD32VF103CBT6 development boards which come with a 108MHz 32-bit RISC-V core packed with all the peripherals including USB and 128kB Flash and 32kB RAM. The board also has a 160x96 color tft and uSD and a USB-C connector etc.
I want to use these in the next generation of USB serial and support chips as there is one available in QFN36 but even the 7x7mm LQFP48 is not bad.
At the moment I have managed to install all the dev tools and working with PlatformIO in the VS IDE. I've used a RISC-V version of mecrisp Forth to talk to the board but I will develop a Forth along Tachyon lines for it so I can drop a chip onto a board and program it serially via the host P1/P2 as required.
I have USB serial dongle connected to the pin header for this and needed 3.3V but my dongle only had 5V, so I took a chance that the current wouldn't be too high and inserted a red LED from 5V to 3.3V (about 1.8V drop) and it works fine and the LED is still working.
fibos
fibo(6 )  = 8
fibo(7 )  = 13
fibo(8 )  = 21
fibo(9 )  = 34
fibo(10 )  = 55
fibo(11 )  = 89
fibo(12 )  = 144
fibo(13 )  = 233
fibo(14 )  = 377
fibo(15 )  = 610
fibo(16 )  = 987
fibo(17 )  = 1597
fibo(18 )  = 2584
fibo(19 )  = 4181
fibo(20 )  = 6765
fibo(21 )  = 10946
fibo(22 )  = 17711
fibo(23 )  = 28657
fibo(24 )  = 46368
fibo(25 )  = 75025
fibo(26 )  = 121393
fibo(27 )  = 196418
fibo(28 )  = 317811
fibo(29 )  = 514229
fibo(30 )  = 832040
fibo(31 )  = 1346269
fibo(32 )  = 2178309
fibo(33 )  = 3524578
fibo(34 )  = 5702887
fibo(35 )  = 9227465
fibo(36 )  = 14930352
fibo(37 )  = 24157817
fibo(38 )  = 39088169
fibo(39 )  = 63245986
fibo(40 )  = 102334155
fibo(41 )  = 165580141
fibo(42 )  = 267914296
fibo(43 )  = 433494437
fibo(44 )  = 701408733
fibo(45 )  = 1134903170
fibo(46 )  = 1836311903  ok.
Here's a photo next to an older P2D2
4618 x 3464 - 1M
  • jmgjmg Posts: 14,650
    There was an interesting die image of this family posted here
    https://www.eevblog.com/forum/microcontrollers/risc-v-microcontrollers-from-gigadevice/msg3027160/#msg3027160
    Appears to have a stacked flash die.
  • Cluso99Cluso99 Posts: 17,686
    edited 2020-10-10 21:07
    Peter,
    Nice find! Did it come with the plastic case too?
    Would be nice to find a cheap micro that can connect a USB keyboard and USB mouse to a serial port(s) for connecting into a P1 or P2 using 1 or 2 pins.
  • Peter JakackiPeter Jakacki Posts: 10,166
    edited 2020-10-10 23:12
    Yes, it had the snap together case. I made the mistake of connecting up the USB-C to power it and trying to load Forth onto it via the pin header serial which has the default bootloader, but it wouldn't work. Finally I disconnected the USB-C and used the LED voltage drop trick for 3.3ish volts and it worked.
    I have been pouring over RISC-V documents and simulators and lecture notes on assembly language etc and the ISA is indeed strange. There are no condition codes and the conditional jumps do the "compare" and branch. The equivalent to augs to load 32-bits but not is lui which loads the upper 20 bits directly into the register and so therefore you need to do an addi or similar to add in the lsbs, although there is a corner case due to automatic sign extension.
    To load register x10 with "0xDEADBEEF" (corner case exeception)
    lui x10,0xDEADC
    addi x10,x10,0xEEF
    It's not as pretty as I had hoped, but it works. So much nicer always having 32-1 registers usable instead of the Cortex crippling registers.
    The USB on the GD32VF103 is OTG so I can also host devices.
    @jmg - Interesting that they must load Flash into hidden RAM for zero wait states then.
  • AribaAriba Posts: 2,458
    edited 2020-10-11 00:39
    lui x10,0xDEADC
    addi x10,x10,0xEEF
    for sure you can also write:
      li  x10, #0xDEADBEEF
    and the assembler will generate the LUI and the ADDI instruction for you, just like
    mov reg,##$DEADBEEF with P2 assembly.
    Andy
    edited 2020-10-11 00:49
    @Ariba - yes, there are lots of pseudo instructions that take care of these things. I always like to understand it without all the extra layers added or hidden.
    For instance, there is no move register or a jump instruction etc but they use the encoding to achieve this in one instruction whereas others such as "long 32-bit immediate" must use two instructions and compensate for sign extension.
    Since I like to write a Forth that really groks the ISA, I need to understand it well so that I can even write my own assembler if need be which is sometimes necessary just to get it to work the way you need.
    After having worked with ARM and Prop conditional ALU operations, I am once again having to work with none :)
  • I know you are terribly busy but since that is a permanent state then I thought I'd better ask now and wait patiently for an answer.
    Do you have any update for us poor souls ?
    I saw another Risc-V module on your microMat board in the P2D2 thread so hopefully you didn't abandoned that project, did you ?
