How to convert Google Doc to PDF?
ManAtWork
Does anybody know how the Google docs from the P2 developper site can be converted to a PDF which includes bookmarks? Of course, we can print it online which generates a PDF file or download it as PDF. But this discards the "table of contents" (TOC) list on the left side and makes a quick jump to individual chapters difficult. I even tried to export the doc as ODF because Open Office has a PDF export function including bookmarks (Word doesn't). But the links of the TOC are also discarded when the doc is converted to ODF format.
I'd really like to have an offline version of the documents on my PC) desktop because I have to look up many details about instructions, smarpins etc. quite often and my internet connection is quite slow. I fear I have to do it the old fashioned way: Print it on physical paper, bind it and add yellow stickers as tabs to each chapter...
EDIT: I was wrong, Word also has an option to export to PDF with bookmarks. It just was so well hidden I haven't noticed. See Bobs post below.
If you have MS Word you can export as a Word Doc .
Then follow this:
How to Retain Bookmarks When You Convert From Word to PDF
https://smallbusiness.chron.com/retain-bookmarks-convert-word-pdf-54126.html
It's work a shot but I don't have Word to try it for you .
Bob
I inserted the Table of Contents at the top of the second page (before the Design Status title.
And thanks, Roy. That's also a good idea but I prefer bookmarks over TOC links because I can keep the bookmark tab open all the time so I have a good overview. Bookmarks of sub-chapters can also be collapsed and expanded.
The latest Spind2 Documentation seems to be broken somehow. There is a header on each page that startes with "ith 1..8 channels, can trigger on level with hysteresis", a block of code and an animated GIF. This seems to confuse the DOCX export also and prevents it from generating a proper TOC.
