P2 wireless HDMI transmission (WHDI)
Tubular
Yesterday I successfully tested using a 5.8GHz wireless HDMI sender with the Prop2
Happy to say got good results out to at least 15m line of sight, and ~8m through a concrete wall
These transmit using 5.8 GHz band. Jaycar have a special on these at the moment. There are various versions but I like these because of the compact transmitting dongle (rather than a desk mounted box)
I added a dual output Lipo chargepack for portable testing. There is something cool about having your whole setup battery powered, but viewing the output from Rogloh's DVI driver on a big TV across the room
I can't get Chip's hdmi spiral demo to work right just yet (it comes up distorted), but will dig deeper. It does work when directly driving the same TV used with this testing.
Regarding Chip's demo vs DVI driver output working, it must be resolution/timing related somehow.
One other thing, they also send audio and extend an IR remote control. The audio helps us with the P2 since audio-over-hdmi is at early stage. But also wondering whether the IR channel could be repurposed for a serial transmission channel
It's be handy to emulate a mouse or other controller with cursor movement/mouse click etc using a GUI on the P2 via a control channel such as this. If you wanted it as a general purpose unidirectional serial channel it's likely to be very low bandwidth given how IR encoding works. You'd need some other device at the sending end to take your serial data from somewhere and modulate it into IR pulses too, but just about any micro could do that. One application there is a remote keyboard input via IR. Easy P1 project.
