Spin2 - Conversion from P1 Spin to P2 Spin2 - discussion and questions
Cluso99
in Propeller 2
Just trying to understand what is required for converting some routines...
I realise this is not the most efficient, as it would be faster to use if ... else return:=0
In the case above, what happens with the quit statement?
None of this takes the abort into account which I'll have to deal with later.
PUB readByte ' returns a byte readData(@result, 1) --becomes-------------------------------------------------------------- PUB readByte() : ch ' returns a byte (actually it returns a long) ch := readData(@result, 1)Is result still defined in spin2???
PUB readString(stringPointer, maximumStringLength) if(stringPointer and (maximumStringLength > 0)) result := stringPointer bytefill(stringPointer--, 0, maximumStringLength--) repeat while(maximumStringLength--) ifnot( readData(++stringPointer, 1) and byte[stringPointer] and (byte[stringPointer] <> 10) and (byte[stringPointer] <> 13) ) quit --becomes-------------------------------------------------------------- PUB readString(stringPointer, maximumStringLength) : result result := 0 if(stringPointer and (maximumStringLength > 0)) result := stringPointer bytefill(stringPointer--, 0, maximumStringLength--) repeat while(maximumStringLength--) ifnot( readData(++stringPointer, 1) and byte[stringPointer] and (byte[stringPointer] <> 10) and (byte[stringPointer] <> 13) ) quitI have presumed here that result is no pre-initialised to 0, so I must explicitly do this now.
PUB writeData(addressToGet, count) | stride result := addressToGet if(lockFileSystem("W") and fileOpenCloseFlag and fileReadWriteFlag) count := ((count <# (posx - currentPosition)) #> 0) repeat while(count) if(((currentPosition >> 9) > currentSector) and fileBlockDirtyFlag) fileBlockDirtyFlag := false readWriteCurrentSector("W") currentByte := currentPosition ifnot(readWriteCurrentCluster("W")) quit stride := (count <# (512 - currentByteInSector)) bytemove(addressDIREntry, addressToGet, stride) currentPosition += stride addressToGet += stride count -= stride currentSize #>= currentPosition fileBlockDirtyFlag := true unlockFileSystem return (addressToGet - result) --becomes-------------------------------------------------------------- PUB writeData(addressToGet, count) : result | stride result := addressToGet if(lockFileSystem("W") and fileOpenCloseFlag and fileReadWriteFlag) count := ((count <# (posx - currentPosition)) #> 0) repeat while(count) if(((currentPosition >> 9) > currentSector) and fileBlockDirtyFlag) fileBlockDirtyFlag := false readWriteCurrentSector("W") currentByte := currentPosition ifnot(readWriteCurrentCluster("W")) quit stride := (count <# (512 - currentByteInSector)) bytemove(addressDIREntry, addressToGet, stride) currentPosition += stride addressToGet += stride count -= stride currentSize #>= currentPosition fileBlockDirtyFlag := true unlockFileSystem result := (addressToGet - result)Again, I presume we don't have result so I need to declare it, and the return needs to become a result := (addressToGet - result)
Plain ABORT without an argument returns 0, while 'ABORT value' returns 'value'.
That makes it easier. Just have to ensure I preset the result to 0 first.
Note: Spin1 has a limit of a single long returned. Using this as a basis...
1. If there is no "(" following (ie no calling parameters) then PUB/PRI requires "()" following it. Spaces allowed.
2. If the PUB/PRI returns a value, then the PUB/PRI needs the inclusion after the ")" of " : result"
3. There is no default set for result. Therefore, if a default result of zero is required, then the line result := 0 must be inserted as the first statement. Code improvement can be done later.
4. Single statements of method(params) that actually return a result need to be converted to result := method(params)
Other changes:
-- P2 methods can return multiple values (all must be declared)
-- P2 local variables can be longs (default), words (must be declared by type), or bytes (must be declared by type)
Yes, I have passed a pointer to an array where I’ve used and updated variables in that array. It’s perhaps more common too. Certainly passing a pointer to a list of known parameters is quite common - eg a set of parameters for a list of pins, or a set of vga parameters.
Of course these will still work as-is in spin2.
