Shop
Learn
designing with propeller 1 — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Customer Projects
zoraster
10
2020-03-27 16:09
in
Customer Projects
I want to use the propeller in a custom robot and I'm wondering what kind of buffering is needed for the propeller chip
Publison
11,892
2020-03-27 16:17
Not sure what you mean by "buffering".
Do you mean voltage translator:
https://www.google.com/search?sxsrf=ALeKk03wI1mbCJoQ1OHswawjQL7j3WdkIA:1585325711107&ei=jyZ-XoiXBu-Jggev7K2gDQ&q=voltage+level+translators&oq=voltage+level+translators&gs_lcp=CgZwc3ktYWIQARgAMgIIADIGCAAQChAeMgYIABAFEB4yBggAEAUQHjIFCAAQzQIyBQgAEM0CMgUIABDNAjoECAAQRzoHCCMQsAIQJzoGCAAQBxAeOggIABAHEAoQHjoGCAAQDRAeOgoIABANEAUQChAeOggIABANEAUQHjoICAAQBxAFEB5QpsABWIXXAWC_7gFoAHACeACAAXWIAdQFkgEDNy4xmAEAoAEBqgEHZ3dzLXdpeg&sclient=psy-ab
or serial:
https://www.ftdichip.com/USB.html
JonnyMac
7,553
2020-03-28 01:48
Depends what you're connecting to. If the device is compatible with 3.3v logic, nothing needed. If you have a 5v signal coming in, you can protect the Propeller IO pin with a 4.7K resistor.
Sign In
Register
to comment.
or serial:
