Welcome to the Parallax Discussion Forums, sign-up to participate.
Project Directory: C:/Users/pwerner/Documents/RoboScape Firmware 2019-08-05/firmware/ SimpleIDE Version 1.1.2 C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/ C:/Users/pwerner/Documents/SimpleIDE/ Updated on: 2020-03-04 propeller-elf-gcc.exe -v GCC 4.6.1 (propellergcc_v1_0_0_2408) propeller-elf-gcc.exe -I . -L . -I C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools -L C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools/cmm/ -I C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext -L C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext/cmm/ -I C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c -L C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c/cmm/ -I C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libfdserial -L C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libfdserial/cmm/ -I C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/Sensor/libping -L C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/Sensor/libping/cmm/ -Os -mcmm -m32bit-doubles -fno-exceptions -std=c99 -c xbee.c -o cmm/xbee.o propeller-elf-gcc.exe -I . -L . -I C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools -L C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools/cmm/ -I C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext -L C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext/cmm/ -I C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c -L C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c/cmm/ -I C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libfdserial -L C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libfdserial/cmm/ -I C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/Sensor/libping -L C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/Sensor/libping/cmm/ -Os -mcmm -m32bit-doubles -fno-exceptions -std=c99 -c melody.c -o cmm/melody.o propeller-elf-gcc.exe -I . -L . -I C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools -L C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools/cmm/ -I C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext -L C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext/cmm/ -I C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c -L C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c/cmm/ -I C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libfdserial -L C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libfdserial/cmm/ -I C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/Sensor/libping -L C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/Sensor/libping/cmm/ -o roboscape.elf -Os -mcmm -m32bit-doubles -fno-exceptions -std=c99 cmm/xbee.o cmm/melody.o -ffunction-sections -fdata-sections -Wl,--gc-sections roboscape.c -lm -lsimpletools -lsimpletext -lsimplei2c -lfdserial -lping -lm -lsimpletools -lsimpletext -lsimplei2c -lfdserial -lm -lsimpletools -lsimpletext -lsimplei2c -lm -lsimpletools -lsimpletext -lm -lsimpletools -lm roboscape.c: In function 'software_reset_xbee': roboscape.c:176:25: warning: unknown escape sequence: '\8' [enabled by default] C:\Users\pwerner\AppData\Local\Temp\ccqBgqK1.o: In function `.L50': (.text.startup.main+0x30f): undefined reference to `_drive_speed' C:\Users\pwerner\AppData\Local\Temp\ccqBgqK1.o: In function `.L50': (.text.startup.main+0x34b): undefined reference to `_drive_getTicks' C:\Users\pwerner\AppData\Local\Temp\ccqBgqK1.o: In function `.L50': (.text.startup.main+0x3a3): undefined reference to `_drive_goto ' collect2: ld returned 1 exit status Done. Build Failed! Check source for bad function call or global variable name `_drive_speed' C:\Users\pwerner\AppData\Local\Temp\ccqBgqK1.o: In function `.L50': (.text.startup.main+0x34b):
The link section is missing this library.
BTW: In the project did you use the "Add Simple Library" in the Project menu to add the libabdrive library to your project? It lives in the Robotics/ActivityBot360 (or Robotics/ActivityBot) directory within the Simple Libraries path. That will include the abdrive.h file in your source but also add it to the linker portion of the command that builds your project. In your posting of the error codes, I don't see something like: "-I C:/Users/pwerner/Documents/SimpleIDE/Learn/Simple Libraries/Robotics/ActivityBot/libabdrive", which would be required to link your project.
dgately
#include "abdrive360.h"
...those particular compiler errors might just clear right up.
Thank you again! This Parallax Forum is outstanding!
Great news! Rocklin ROCKS1
