smart pins and events
ManAtWork
in Propeller 2
Today I tried talking to an absolute encoder of a servo motor from Sanyo Denki. It has a rather strange protocol, an asynchronous serial RS485 line (bi-directional half duplex) but with 16 bit frames instead of 8 and a CRC3 for sending and CRC8 for receiving with non-standard polynomials. So it's a good test for the capabilities of the P2.
Everything went surprisingly well and I got answers from the encoder on the fist go. However, I've noticed that the received words were somhow shifted. I got the first data word in place of the second, the second in the third and the first (status) contained garbage. I found out that the first WAITSE didn't work and fell through immediately. So I tried out some things and found out that the IN bit of the smartpin seems not to be reset by a DIR=0. If I insert an AKPIN and a POLLSE the WAITSE works as expected.
Is this normal behaviour or have I done something wrong? No big problem but I think it should be documented.
drvl #pinEncTe fltl #pinEncTx ' reset smartpin wrpin mode_stx,#pinEncTx ' synchronous serial transmit wxpin baud_bits,#pinEncTx ' 2.5MBd 16N1 drvl #pinEncTx ' enable TX smartpin fltl #pinEncRx ' reset smartpin wrpin mode_srx,#pinEncRx ' synchronous serial receive wxpin baud_bits,#pinEncRx ' 2.5MBd 16N1 ' don't enable RX smartpin, it'd read TX data (loopback) setse2 #%001_000000 + pinEncRx ' IN rises txLoop drvh #pinEncTe waitx bitTime ' output enable delay wypin cmdCDF1,#pinEncTx ' start transmission waitx bitTime ' busy flag is not valid before start bit out .busy rqpin rxd,#pinEncTx wc ' read busy flag -> C if_c jmp #.busy ' wait for TX complete waitx bitTime drvl #pinEncTe drvl #pinEncRx ' enable RX smartpin akpin #pinEncRx ' force IN low pollse2 ' purge false event waitse2 rdpin status,#pinEncRx shr status,#16 waitse2 rdpin pos,#pinEncRx ' receive pos LSW shr pos,#16 waitse2 rdpin rxd,#pinEncRx ' receive pos MSB + CRC shr rxd,#16 and rxd,#$FF shl rxd,#16 or pos,rxd ' merge MSB+LSW to 24 bits getct time setq #2 wrlong pos,ptra ' write pos + time waitx cycleTime jmp #txLoop ' %AAAA_BBBB_FFF_PPPPPPPPPPPPP_TT_MMMMM_0 mode_stx long %0000_0000_000_0000000000000_01_11110_0 mode_srx long %0000_0000_000_0000000000000_00_11111_0 baud_bits long $10000*72 + 15 ' 2.5MBd 16N1 ' CRC CC EA FC SC cmdCDF1 long %100_00001_000_00_010 cycleTime long 18000 ' 1ms bitTime long 72 pos long 0 time long 0 errCnt long 0 rxd res 1 status res 1And BTW, the busy flag for sending is also undefined directly after starting a transmission. I have to wait some time before polling it, otherwise the busy flag polling loop is terminated immediately.
If you place the SETSE2 after the AKPIN then the POLLSE2 can probably be removed.
