Yes, FlexC allows local labels, using whatever form (colon or dot) is appropriate for the processor being compiled for (colon for P1, dot for P2). For example:
#include <propeller2.h>
__pasm {
entry
nop
.somelocal
dirnot #56
waitx ##20_000_000
jmp #.somelocal
bar
int main () {
_cognew(&entry, 0);
for(;;)
return(0);
Ah, I see: it doesn't like ".0" and ".2" (it wants the local labels to start with a letter or underscore). Does PNut allow local labels to start with a digit? I'd kind of be surprised if it does, those look like floating point numbers, but I'll go along with whatever Chip does.
I changed all labels to DOT-ALPHA. Here are the results
"C:/tools/PropellerTools/flexgui/bin/fastspin" -2 -l -O1 -I "C:/Projects/Prop2Test/flexgui/include" "C:/Projects/Prop2Posit/PositTest.c"
Propeller Spin/PASM Compiler 'FastSpin' (c) 2011-2019 Total Spectrum Software Inc.
Version 4.0.5 Compiled on: Dec 19 2019
PositTest.c
Posit32es2.p2asm:660: error: syntax error, unexpected '.'
Posit32es2.p2asm:664: error: syntax error, unexpected '.'
Posit32es2.p2asm:666: error: syntax error, unexpected '.'
Posit32es2.p2asm:668: error: syntax error, unexpected '.'
Posit32es2.p2asm:672: error: syntax error, unexpected '.'
Posit32es2.p2asm:674: error: syntax error, unexpected '.'
child process exited abnormally
Finished at Tue Jan 14 14:47:03 2020
Code follows:
659 mov temp1,#quire_msw
660 sets .A,temp1
661 mov cntr1,#16
662 mov k_expA,#271
663
664 .A mov frac64Ah,#0 wz
665 if_z sub temp1,#1
666 if_z sets .A,temp1
667 if_z sub k_expA,#32
668 if_z djnz cntr1,#.A
669
670 ' Copy next 2 words to frac64A l and x
671
672 sets .B,temp1
673 sub temp1,#1
674 sets .C,temp1
675
676 .B mov frac64Al,frac64Al
677 .C mov frac64Ax,frac64Ax
Something weird is definitely going on, I was sure that I compiled and ran the program I posted earlier, but now I can't. I must have mixed up compiler versions or something. Sorry about that, I'll look into it. There must be a conflict between the C parser and the Spin parser in __pasm blocks.
OK, the bug seems to be in handling any single character local label in C code in P2 mode; a little specific and I missed it. Basically local labels have to start with two letters or underscores to be properly recognized in fastspin 4.0.x. It'll be fixed in 4.1.0.
Now local labels don't work. I get the following messages.
Code follows:
Code follows:
