P2-EVAL 3D Printed Base — Parallax Forums
Here is a 3D printed base. It has a 2mm thick base with 2mm higher standoffs around the mounting holes of 2.9mm, and 2mm around the entire edge. It's just under the edge of the pcb. The holes take M3 screws 5mm long so you can screw into the plastic without nuts. Note the holes are marginally off the physical pcb mounting holes (maybe 0.2mm???) but the screws do their job nicely so I didn't bother changing the design. I used 10% infill and my Ender 3 took a little under 2 hours to print it.
503 x 343 - 40K
