Flexgui on windows 10
frank freedman
Tried to install and run on windows 10. icon appears on the task bar, but no gui, nothing at all on screen. Anyone have this running on windows 10?
Did you try an earlier version of flexgui (or spin2gui) at some point in the past? Perhaps an old config file is left over. It'd be worth trying to delete all old versions of flexgui/spin2gui and re-installing flexgui from the .zip file.
Flexgui works without problems on linux. You just have to compile fastspin and consorts, which is just a simple 'make' . And Flexgui is a TCL script, which you can just run
This is the latest from github
This is what happened on my machine, pilot315 did not indicate the failure indications in the last post so my fix may or may not be of use. BST presented witht he same behavior, may try the directory fix with that next.
