PMIC for P2 boards?
Rayman
in Propeller 2
Anybody think a Power Management ICs is a good idea for P2 boards?
Is it overkill? Maybe...
I'm looking at the MAX77714 right now...
Unfortunately, most of the PMICs I've found, the above included, target a core voltage <1.8 V.
But, this one has several buck converters and we could just not use the low voltage one.
What's nice is that it also has an RTC (that doesn't need a crystal) and a WatchDog timer.
There are some simpler ones like this: TPS65053
But, I haven't found one that's a perfect fit for 1.8V core yet... Anybody know of a better option?
Soon to be stocked at DK & Mouser.
Now in stock at DK, and due 22nd Mouser.
Also in stock, as a possible '2nd BOM source' is NCV8187AMT330TAG (Automotive version 2x2 package, slightly higher price)
1V8 selection is trickier, and can depend on what matters ? :
* Do you need > 5V DC in, or is 5V/USB in OK
* Do you need integrated inductor, or is external inductor ok ?
* Do you want fine trim of VDD for power/speed trade offs ?
* is BGA ok, or is DFN/QFN preferred ?
Example: for 5.5V max in, and lowest cost/external inductor, in DFN package, I like the look of AP3441LSHE-7B
My notes say :
AP3441SHE-7B Diodes LV BUCK 2.7V~5.5V 0.6V~5.5V 3A 1MHz PGood -40°C ~ 85°C (TA) 8.2 °C/W 8-VFDFN U-DFN2020-8 2x2mm 72mΩ 52mΩ << NEW low cost $0.14603/3k
or, if i2c and pin-select PSU flexibility are needed, this OnSemi part looks interesting, ( 1.10 VSEL should be ok for P2 RAM retention ?)
NCV6357A 3.0 × 4.0 mm / 0.5 mm Pitch DFN 14 Package 5A 39 <60 mΩ 32 <45 mΩ 76c/3k
• Programmable Output Voltage: 0.6 V to 3.3 V in 12.5 mV Steps 1.8V default, 1.10V VSEL in 2 order codes : NCV6357A NCV6357C
• Up to 2.4 MHz Switching Frequency with On Chip Oscillator
• I2C Control Interface with Interrupt and Dynamic Voltage Scaling Support
I can actually use the 1.5 V regulator to supply power to the RTC on an FTDI chip...
Seems like plenty to me...
I think usually you want the core to get power before the I/O...
