P2 cogexec vs hubexec vs overlay timings
Cluso99
in Propeller 2
Curious to see just how cogexec vs hubexec vs overlay timings would stack up, I ran some tests...
Overlay loads the hub block into cog and executes from cog.
Here is the routine that I tested, with a small loop repeated 'loops' times where 1=no loop.
And overlays don't seem worth the trouble unless there are a lot of loops.
getct ctr1 call #olay ' *** cogexec *** getct ctr2 ............. rdlong y,olayptr ' set known hub rotation getct ctr1 call #hub_test ' *** hubexec test *** getct ctr2 ............. rdlong y,olayptr2 ' set known hub rotation getct ctr1 setq #hub_test2_end - hub_test2 -1 ' *** overlay length to load rdlong olay, olayptr call #olay getct ctr2a ............. hub_test mov z, loopctr ' 1 .loop add x, #1 ' 2 add x, #1 ' 3 add x, #1 ' 4 add x, #1 ' 5 add x, #1 ' 6 add x, #1 ' 7 add x, #1 ' 8 add x, #1 ' 9 add x, #1 '10 add x, #1 ' 1 add x, #1 ' 2 add x, #1 ' 3 add x, #1 ' 4 add x, #1 ' 5 add x, #1 ' 6 add x, #1 ' 7 add x, #1 ' 8 add x, #1 ' 9 add x, #1 '10 add x, #1 ' 1 add x, #1 ' 2 add x, #1 ' 3 add x, #1 ' 4 add x, #1 ' 5 .loop2 add x, #1 ' 6 add x, #1 ' 7 add x, #1 ' 8 add x, #1 ' 9 djnz z, #.loop2 '10 ret hub_test_endand here are the results (clocks in hex)...
loops: cogexec hubexec overlay 0A: 000000B2 00000128 000000DE (178 296 222) 09: 000000A6 00000110 000000D2 08: 0000009A 000000F8 000000C6 07: 0000008E 000000E0 000000BA 06: 00000082 000000C8 000000AE 05: 00000076 000000B0 000000A2 (118 176 162) 04: 0000006A 00000098 00000096 03: 0000005E 00000080 0000008A ( 94 128 138) 02: 00000052 00000068 0000007E 01: 00000046 00000051 00000072 (70 81 114)So roughly there is an 11 clock overhead for hubexec over cogexec for each load/loop.
