ePaper Display (28084)
I'm enjoying playing with this display wired to a FLIP; have displayed large fonts, different orientations, random numbers, programs running from EEPROM.
However, I may have already partly damaged it. When the display toggles from "white paper" to black, there are multiple vertical white lines in the black.
The Product ID 28084 Details Key Specifications page says "Operating voltage: 3.3V/5V".
I took this to mean the display would operate on either 3.3 volts or 5 volts. But when connected to the FLIP USB5V pin, nothing on the display at all. Does not do the black / white / black / white routine when powered up to get rid of ghosting. My multimeter shows this pin to have 5 volts. Then when hooked back to the FLIP 3.3 volt pin, it works.
The Waveshare Specifications page 17 Maximum Ratings says: "Logic supply voltage -0.5 to +4.0 volts." This makes me think the device should be connected only to 3.3 volts.
  • I may be wrong about not using 5 volts. In the Waveshare User Manual it states under Specification "Operating Voltage 3.3V/5V (but keep all input pins the same, either 3.3V or 5V.
    The weird thing is, all examples given by Waveshare (Pi, Arduino, STM32) say to hook the module up to 3.3 volts.
    It might be that the module has a chip on it to convert incoming 5 volts to 3.3 for the ePaper "raw panel" as they call it but I cannot tell since the chip looks proprietary.
    I tried again using the USB 5V FLIP pin and still nothing. Then tried 5 volts from my Rigol (gnd to FLIP gnd, 5v to ePaper Vcc). It worked for a short time and then stopped. Before it stopped it displayed a thick white band about 2/3 down the display against the black, like it could not be refreshed correctly.
    After which it would not work on the FLIP 3.3V. After disconnecting and letting it sit for 5 minutes, it now again works from the FLIP 3.3V.
    Perhaps I need to rewire on a different breadboard with different wires to see if there is some sort of intermittent. Or perhaps this specific module really does not like having 5 volts applied ???
  • I think that it may indeed not be liking having 3.3v logic while connected to 5v power. Maybe it causes partial logic switching(brownout).
  • Since supply voltage and I-o voltage should be the same as stated, and Propeller I-O is 3.3v my guess is you should use 3.3v not 5v.
  • Ken GraceyKen Gracey Posts: 6,857
    edited 2019-08-05 - 17:09:05
    From David Carrier, on an internal communication:
    The schematic for the ePaper module is posted here: https://www.waveshare.com/w/upload/8/85/2.9inch_e-Paper_Schematic.pdf. It uses a TXS0108E level converter, which has a set of 'A' pins for the lower-voltage device and a set of 'B' pins for the higher-voltage device. The 'B' pins are connected to the external I/O and have an absolute maximum voltage rated at 6.5 volts, regardless of Vccb. They do have a recommended high input voltage of Vccb, but signals exceeding Vccb, while still under 6.5 volts, should not cause any damage, although it could cause undesired operation.
    So, it doesn't seem that 5V input is a problem. This is a Waveshare-supplied product, as you noted.
    I'd be happy to replace it for you. Contact me offline for an RMA kgracey@parallax.com
    [update: according to Michael your display is working, so disregard this message. But, if anybody ever needs service from us just say something. I don't often monitor the forums so feel free to draw my attention to possible RMA issues quickly via email kgracey@parallax.com]
  • Another example of Parallax’s amazing customer service! Always there!
  • Thank you for all the responses. I'm convinced my ePaper display is working at 3.3 volts. And I'm convinced that the weird behavior I saw at 5 volts was due to USER error; I ignored keeping signals and Vcc at same voltage.
    I will investigate this more. But thanks to all.
  • RobR - I've seen the same thing you are seeing, but I've noticed something. Once the display becomes unresponsive, unplug it for a long while (something on the order of an hour) and it will be ready to experiment with again.
    I agree with you, I think the issue is with commands I'm sending to the display and there is nothing wrong with the display.
    I haven't been able to change the size of the font - do you have any hints you can share?
    Tom
  • LtechLtech Posts: 257
    edited 2019-09-12 - 18:55:32
    Can I have a RMA Please
    I only need 4 cogs for the job.
    :clown:
    2016 x 1512 - 757K
    1512 x 2016 - 768K
  • PublisonPublison Posts: 11,661
    edited 2019-09-12 - 19:47:27
    Ltech wrote: »
    :clown:
    You need to email sales@parallax.com
    support@parallax.com
    for am RMA.
    I just got the joke. :)
  • Ltech wrote: »
    :clown:
    You really cut that one down? Not Photoshop?
    I almost killed one of my precious Parallax P1 Protoboard without USB by just drilling a mounting hole right thru the somewhere hidden reset connecting PCB part, naturally AFTER I populated the complete board, you know, come on Mike just one more screw and it will be more robust and look better. Yeah.
    Took me days to find out and fix that by carefully cleaning the new created via from reset to ground and rewire the reset button.
    I did, on the other hand, cut out the USB part of new Protoboards successful to regain P31/30 and another PropPlug…
    edited 2019-09-13 - 06:42:45
    Somebody puts 24 Volt on a pin expected a puls from GPS @3,3Volt.
    To save the whole board, I take a Dremel and cut the flip away.
    I don't want to stress the main pcb.
    After soldering a new Flip it runs fine again.
    I saved a board of 200$ by cutting a Flip.
    So no Photoshop.
  • Ah, I was looking at the destroyed Dremel'd plastic and was unsure if one of the halves is still alive.
    Someone here DID Dremel'd off a P1 DIP, cutting thru plastic, not destroying the internal chip. And had it still running.
  • Unlike a normal display where the controller on the display constantly updates the display, on the ePaper display it does not want that. It will burn the image if it is left in refresh mode too long.
    It is like burning an EEPROM where you write to the display once and then shut everything down. Even power and the display stays the way you burned it.
    I wrote my own driver for this display and found the information very confusing and not very friendly. The only reason you need a controller on this display is for the burning process that requires some strange voltages to update the display pixels.
  • So, could you post the (open) side view of that flip? I’m curious.
    edited 2019-09-18 - 20:22:17
    2016 x 1512 - 718K
    1512 x 2016 - 492K
  • Thnx!
    I see bits of copper
