DS1302 RealTimeClock/event timing issue
in Propeller 1
I'm using the ds1302 rtc that's built into the ppdb, and the "DS_fulldemo.spin from OBEX. I've added my own little bit of code at the bottom of the demo. The goal is to use it for timing based events. So far i'm just experimenting with toggling a led based on the seconds. That works for any given second 0-59. When i add an "OR" to the if condition (if seconds == 1 OR 37 ect.) , the pin toggles each time through the loop, which is once a second. I'm not sure what to try or look for to go forward, any help or idea is appreciated. Thanks
{{ DS1302_full-demo.spin}}
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
OBJ
SN : "Simple_Numbers"
rtc : "DS1302_full"
debug : "SerialMirror" 'Same as fullDuplexSerial, but can also call from subroutines
VAR
byte hour, minute, second, day, month, year, dow
byte cmd, out
byte data[12]
long activitiesStack[75]
PUB main|i,_month,_day,_year,_dow,_hour,_min,_sec
dira[10]~~
waitcnt(clkfreq * 5 + cnt) 'wait 5 secs, start FullDuplexSerial
Debug.start(31, 30, 0, 115200)
Debug.Str(String("MSG,Initializing...",13))
'call this function each time the propeller starts
rtc.init( 4, 5, 6 ) 'ports Clock, io, chip enable
'set time
debug.str(string("=========== DS1302 demo ===========",13))
debug.str(string("enter 1 to setup ds1302, 0 to proceed on to demo without setting time",13))
if(debug.GetNumber<>0)
debug.str(string("enter month (1-12)",13))
_month:=debug.getnumber
debug.str(string("enter day (1-31)",13))
_day:=debug.getnumber
debug.str(string("enter year (00-99)",13))
_year:=debug.getnumber
debug.str(string("enter day of week (1-7)",13))
_dow:=debug.getnumber
debug.str(string("enter hour (0-23)",13))
_hour:=debug.getnumber
debug.str(string("enter minute (0-60)",13))
_min:=debug.getnumber
debug.str(string("enter second (0-60)",13))
_sec:=debug.getnumber
'call this function only after DS1302 power on
rtc.config 'Set configuration register
'call this function to set DS1302 time
rtc.setDatetime( _month, _day, _year, _dow, _hour, _min, _sec ) 'month, day, year, day of week, hour, minute, second
'change the tricle charger setup from that currently defined in the config function
'Trickle charger setup tc_enable diodeSel resistSel
rtc.write(rtc.command(rtc#clock,rtc#tc,rtc#w),(%1010 << 4) + (1 << 2)+ ( 1 ))
out:=rtc.read(rtc.command(rtc#clock,rtc#tc,rtc#r))
Debug.Str(string("Trickle charge register contents = "))
Debug.bin(out,8)
Debug.Str(String(13,13))
'write data values to ram registers
repeat i from 0 to 30
cmd:=rtc.command(rtc#ram,i,rtc#w)
Debug.Str(string("Writing RAM address "))
Debug.Dec(i)
Debug.Str(string(" cmd byte = "))
Debug.Bin(cmd,8)
Debug.Str(String(13))
rtc.write(cmd,i)
'read data values from ram registers
cmd:=rtc.command(rtc#ram,i,rtc#r)
Debug.Str(string("Reading RAM address "))
Debug.Dec(i)
Debug.Str(string(" = "))
out:=rtc.read(cmd)
Debug.Dec(out)
'write data to registers 0-11 in burst mode
Debug.Str(string("Writing RAM data in burst mode"))
data[i]:=30-i
cmd:=rtc.command(rtc#ram,rtc#burst,rtc#w)
rtc.writeN(cmd,@data,12)
'read data registers 0-11 in burst mode
Debug.Str(string("Reading RAM data in burst mode",13))
cmd:=rtc.command(rtc#ram,rtc#burst,rtc#r)
rtc.readN(cmd,@data,12)
repeat i from 0 to 11
Debug.Str(string("Data "))
Debug.Dec(i)
Debug.Dec(data[i])
' cognew (activities, @activitiesStack)
'read date and time, once per second
repeat
rtc.readTime( @hour, @minute, @second ) 'read time from DS1302
rtc.readDate( @day, @month, @year, @dow ) 'read date from DS1302
Debug.str( SN.decx(hour,2) )
Debug.str( string(":"))
Debug.str( SN.decx(minute,2) )
Debug.str( string(":") )
Debug.str( SN.decx(second,2))
Debug.str( string(", ") )
Debug.str( SN.decx(dow,2))
Debug.str( string(" ") )
Debug.str( SN.decx(month,2))
Debug.str( SN.decx(day,2))
Debug.str( SN.decx(year,2))
waitcnt( clkfreq + cnt )
activities
pub activities
dira[10]~~
'repeat
if second ==1 or 37 'trigger event based on a time
!outa[10]
you want to write it like this:
Or alternatively
