Older 36 position wheel encoder versus 144 position wheel encoder — Parallax Forums
TCIIITCIII Posts: 81
edited 2019-06-24 17:23 in Robotics
Hi All,
Would appreciate some advice here.
I have an older Eddie Chassis with the original Motor Assemblies and 9 position wheel encoders (giving 36 pulses/revolution) (#27906) that was used with the HB-25s and a Propeller Development Board.
I am planning on replacing the HB-25s and the Propeller Development Board with the DBH-10 Motor Controller and an Arduino BOE.
My question is, can I use the original 9 position wheel encoders with the DBH-10 Motor Controller or should I upgrade to the 36 position wheel encoders (giving 144 pulses/revolution) (#29321)?
Also, if I do upgrade to the 36 position wheel encoder, will the encoder disc fit my original Eddie Chassis motor assembly wheel drive shafts?
TCIII AVD
  • Hi All,
    After rereading the older 9 position wheel encoder (#27906) documentation, it appears that each 9 position wheel encoder/HB-25 combination is equivalent to one of the two motor control channels on the DBH-10 Motor Controller. Like each channel on the DBH-10, each of the 9 position wheel encoders can receive a serial speed/direction/distance input commands and then drive its respective HB-25 appropriately.
    Therefore the older 9 position wheel encoders are obviously not usable with the DBH-10 and since I have already ordered the DBH-10 Motor Controller it looks like I will need to order the 36 position wheel encoders (#29321) to work with the DBH-10 Motor Controller. However, I will now have higher resolution wheel encoders allowing for more accurate speed and distance knowledge.
    TCIII AVD
