Hey guys, I'm flying to Boston with my wife for her business trip. I want to take an activity board and some sensors to play with during the down time. Will TSA let me board with this stuff in my carry-on luggage?
I always bring something to play with when out for training. Analog Discovery 2 module makes it pretty easy to have a full lab on hand. (although my last Cleveland and Boston trips were a bit expensive due to there being a Micro Center in both locations).
Just check it through. Never had any problems. Make sure you have some sort of docs as Publison said. Watch the rules on certain types of batteries.
As to cavity search, as long as you don't put any Lithium batteries in there you should be OK. If not, well you may not be OK. (See all sorts of things working in a hospital, hear about much more than I would have wanted. Gives new meaning to "can't unsee that"
Ordnung ist das halbe Leben
I gave up on that half long ago.........
I've placed my quickstart + breadboard in a cookie tin and brought on a plane in my backpack for use during the flight many times and never been given any trouble at all. No even asks questions about it. Earliest I ever did that was 2012, and the last time I did it was 2017 I think
So.... is it better to check it in or carry it on? I am over thinking this I know, its been 10 years since I have flown anywhere and its nerve racking to me!
So there is a micro center in boston, interesting! I have 3 whole days to do whatever I want, I might have to try and locate it.
Back during the Gulf War I was flying into DFW via Hawaii and I had this great big cardboard box that I had thrown all my development equipment including a Mac and all these bits n pieces and chips and wires and you name it and that at the last moment while trying to finish off before I left. Interestingly I got through customs without a hitch despite the innards lighting up like something fierce but my Italian leather briefcase toting friend got the deluxe show and tell grilling
btw, I couldn't take a Propeller on an airplane anymore ........ not unless it was a vintage Constellation
I have flown with test equipment, spare boards, and electronic parts in my checked luggage as recently as February with no problems. I simply ask that my bags be checked at the oversized luggage/screening area and let them know what is in the baggage and what it is for. Done that for years and never had a problem.
In science there is no authority. There is only experiment.
Life is unpredictable. Eat dessert first.
Right on memorial drive in Cambridge. Conveniently located in the same parking lot as a Trader Joe's. Just think, if they built a big roof over the two, it would be just like Fry's with indoor parking.......
Also with a bit of planning, depending on where you are driving from, it is possible to avoid the tool road in.
Well, my parallax toys made it to Boston! I put them in my checked luggage and there was no problem. I did however get stopped going through the 3D body scanner and patted down. I must have looked suspicious! LOL
Edit: I did print off the pdf manuals for everything I took, and left them at the top of the checkin bag! I did not take any batteries with me either!
If you do fly with batteries, always put them in a carry-on, no matter the chemistry. Usually they're fine with electronics as well; calling them "prototype electronics" is usually enough to not ask further questions.
http://paypal.me/parallaxitems
https://parallax.com/product/32912
And if so should I just print it off?
I am planning on bringing a wall-wart, no batteries.
Can I just throw the jumper wires into a ziplock bag.
P1 Prop OS (also see Sphinx, PropDos, PropCmd, Spinix)
Website: www.clusos.com
P1: Tools (Index) , Emulators (Index) , ZiCog (Z80)
P2: Tools & Code , Tricks & Traps
PropWare: C++ HAL (Hardware Abstraction Layer) for PropGCC; Robust build system using CMake; Integrated Simple Library, libpropeller, and libPropelleruino (Arduino port); Instructions for Eclipse and JetBrain's CLion; Example projects; Doxygen documentation
CI Server: https://ci.zemon.name?guest=1
If its checked, I wasn't sure if they saw something they didn't like if they would keep the whole bag! That would be a problem!
Tachyon Forth - compact, fast, forthwright and interactive
P2 --- The LOT --- TAQOZ INTRO & LINKS --- P2 SHORTFORM DATASHEET --- TAQOZ RELOADED - 64kB binary with room to spare
P1 --- Latest Tachyon with EASYFILE --- Tachyon Forth News Blog --- More
Brisbane, Australia
Thanks for the Advice guys!
Shawn A.
