Servos wrongly connected
I am resuming the programming of my arduino after years using the parallax manuals, but I am stuck in making the servos work.
I have a Basic Stamo Homework Board USB Rev A powered by a UC1.3-6(6V 1.3 AH/20HR) battery.
I can't remember how the servos should be connected to the stamp. I connected them as detailed in the manual (brown cable to Vss, red cable to Vin, orange cable to the pins) and when I power the board there are no lights twinkling and there's a very low whisle.
I hope anyone can help me with the way the servos should be connected.
Thank you all.
4128 x 2322 - 3M
4128 x 2322 - 3M
4128 x 2322 - 3M
  • I have several servos and they all have Black (Vss), Red (Vin), and White (I/O pin) wires. From the photo of the servo wire, I suspect Brown connects to Vss, Red connects to Vin, and Yellow connects to the I/O pin just like what you tried. What program do you have running in the Stamp?
    Your battery puts out over 7V when it's fully charged. That's on the edge of what a servo motor will tolerate. They're much "happier" at 4.5-5V. What happens when you run the Homework Board with 3 or 4 fresh alkaline batteries in series?
  • Hi Mike,
    Thanks for your feedback.
    I wasn't able to download any program to the Stamp, the software shows an error that says that there is no Stamp. I am using version 2.5.4 of the Basic Stamp editor.
    I haven't tried with alkaline batteries yet, but I think this is not a battery issue. I found my boe bot some days ago with both servos connected and the last program I downloaded to the Stamp (which I programmed some years ago) and everything was working fine. Then I disconnected everything to study everything from scratch but I couldn't make it with the servos.
  • PublisonPublison Posts: 11,146
    edited 2019-06-18 - 19:21:32
    The noise you hear might be from the regulator indicating the battery is connected backwards? Try AA batteries as Mike suggested. see if you can see the BS2 without the servo connected.
  • xanaduxanadu Posts: 3,289
    edited 2019-06-18 - 19:32:24
    Those 9v connectors are tricky... Take a multimeter and do a continuity check from the smaller of the two snap connectors to the end of the wires. You'll see the smaller connector is tied to ground (black). This is bad because a 9v battery ground is the larger connector. It is working in reverse because the connectors are designed to get power from the battery, not provide power to a device.
    Just noticed the battery is 6V, that might not be enough. Not sure.
  • What is the voltage going to the servos? There are no servo headers on the homework board to supply 5 volts.
  • Publison wrote: »
    I think the battery is ok because I have programmed the Stamp to control LEDs and provide feedback using the Debug tag and I had no issued with that, the only issue is that I don't remember how to connect the servos.
    Publison wrote: »
    I connected the servo's red cable to Vin and brown to Vss and it measured 3 Volts
  • griegory wrote: »
    Publison wrote: »
    Publison wrote: »
    Where is that voltage coming from, (picture needed). Servos normally need 5 volts to operate.
  • Maybe I'm testing it in the wrong way.
    4128 x 2322 - 3M
  • What pin is the Red lead plugged into?
  • Publison wrote: »
    The (+)Vin pin
  • Vin should read the input voltage of the battery. Does it read 2.9V if you disconnect the servo entirely?
  • Publison wrote: »
    Disconnecting the servos it reads 4.6V
  • 4.6 volts from the battery will not even power up the Homework board. You need 7.5-9 volts.
