Explain in detail/clarify- CON state ments (solved) — Parallax Forums
msiriwardenamsiriwardena Posts: 301
edited 2019-04-12 16:54 in Propeller 1
I am trying to understand the following statements n the con section.
CON
#-1, OPEN[0], OUT, CLOSE
mask = |< 21 | |< 22 | |< 23
I would like someone to explain these two statements so novice can understand.
Thank you,
Siri
  • The first one creates a continuous list of value
    aka
    OPEN[0] = 0
    OUT = 1
    CLOSE = 2
    the second one combines 3 BITS via or
    something = |<21 will produce a long with all bits 0 except BIT 21 high
    so your MASK will be set to a long with all BITS 0 and BIT 21,22,23 set
    Enjoy
  • JonnyMacJonnyMac Posts: 8,927
    edited 2019-04-14 17:01
    The first line holds enumerated constants. The line begins with #, the starting value, a comma, then a list of comma-separated constant names.
    (comment removed due to inaccuracy -- see @ersmith's post below)
    Note, too, that you can change the enumeration value mid-stream. Consider this:
    con
      #0, ALPHA, BETA, GAMMA, #23, OMEGA
    This is the same as:
    con
      ALPHA =  0
      BETA  =  1
      GAMMA =  2
      OMEGA = 23
    The |< operator is shorthand for "1 <<" which is used to create masks. The code above could have been written as
      MASK = (1 << 21) | (1 << 22) | (1 << 23)
    ...which would create a mask with bits 21, 22, and 23 set to 1 (all others cleared to zero).
  • @JonnyMac is right,
    I remembered incorrectly, sorry for any confusion, @msiriwardena.
    Enjoy!
  • The enumeration possibilities in CON are very confusing, even for experts like Jon. In fact:
    CON
    is OK (the square brackets are legal) and is equivalent to:
    CON
      OPEN = -1
      OUT = -1
      CLOSE = 0
    (At least, this is how both fastspin and openspin handle this. bstc doesn't like the "#-1", but it does accept "#(-1)" and then produces the same output as the other compilers.)
    The "#-1" says to start declaring constants with the value "-1".
    The "[0]" after "OPEN" says to skip 0 constants ahead after declaring it; the normal action is to skip 1 ahead. So "OPEN" and "OUT" will be declared to have the same value. If it had read "OPEN[4], OUT" then "OUT" would be "OPEN + 4".
    I think it's a bad idea to use the square brackets inside CON declarations, but they are legal.
    edited 2019-04-14 20:42
    I erred, too.
    My style is to code as obvious as possible. While the index mechanism works and is legal, I would probably code it like this:
    con
      #-1, OPEN, #-1, OUT, CLOSE
    I think it's a bad idea to use the square brackets inside CON declarations...
    Agreed.
  • I think you need a # before the second -1. Even more obvious would be:
    con
      OPEN = -1, OUT = -1, CLOSE = 0
  • Fixed -- posted too early.
    If one is going to skip the enumeration, I think it best to put definitions on their own lines. That's my preference, anyway.
  • ersmith wrote: »
    If it is used for VAR, for example, like "X[0], Y", may produce same address for both X and Y.
    Using same algorithm for CON may produce same value for both X and Y.
