Should ORG imply ORGH?
RossH
in Propeller 2
Ok,
I found what may be a problem with the ORG directive on the P2 (or if it is meant to work this way then it is VERY confusing!). The problem is that using ORG with a non-zero value appears to generate incorrect cog addresses. You can fix it by inserting a corresponding ORGH, but should this really be necessary?
For example, consider this code ...
Everything is fine here. But suppose we remove the long at cog_5 and instead use an ORG directive to instruct the assembler to put the next long at cog location 6 ...
Here, the code generated is correct, but the long labelled cog_6 actually appears at cog location 5. To make it work correctly, I have to uncomment the "cogh" directive.
I'm fairly sure this is not the expected behaviour .... but the P2 is such a strange beast that I am just not 100% sure!
By the way - PNUT and P2ASM both behave the same way.
DAT org $0 cog_0 mov cog_7,cog_6 cog_1 mov cog_6,cog_8 cog_2 mov cog_7,cog_8 cog_3 mov cog_8,cog_6 cog_4 mov cog_6,cog_7 cog_5 long $55555555 ' force next cog address to be 6 cog_6 long $66666666 cog_7 long $77777777 cog_8 long $88888888
DAT org $0 cog_0 mov cog_7,cog_6 cog_1 mov cog_6,cog_8 cog_2 mov cog_7,cog_8 cog_3 mov cog_8,cog_6 cog_4 mov cog_6,cog_7 org $6 ' force next cog address to be 6 ' orgh $6*4 ' force next hub address to match cog address cog_6 long $66666666 cog_7 long $77777777 cog_8 long $88888888
orgf - "fill to"
Note that labels in P2 have two values, their "hub address" and their "default address". After ORGH these are always the same, but after ORG X the "default address" starts over at X but the hub address continues incrementing as before. "@ label" always refers to the hub address of a label, whereas just plain "label" is the default address.
Finally, there are actually 3 assemblers for P2 -- PNut, P2ASM, and fastspin. They all treat ORG and ORGH the same way.
ORGH and ORGF are Prop2 specials.
Well, at least it's consistent! I can't remember using ORG this way on the P1 ... but I am pretty sure I would have been both surprised and annoyed at behaviour like this
On P2, a COG start can happen at non zero addresses, and a COG can go right into HUBEXEC on start too.
Yes, orgf does it. I don't remember that from my P1 days. Thanks.
