Need help !
Hello,
I will be getting a Parallax Propeller Professional board in a week.
Found it on Ebay with nothing else. I need information on what software
is available and needed for this board. I believe there was a CD in the past
but not sure. Is there a copy of the files still available? Also how to set it
up for programming would be very helpful.
Barry
  • Personally, I'd use the Propeller Tool and program in Spin.
    You can find it here: https://www.parallax.com/downloads/propeller-p8x32a-software
    There are also new options if you have a Mac and/or want to program in C.
    Prop Info and Apps: http://www.rayslogic.com/
  • Mike GreenMike Green Posts: 22,915
    edited 2019-03-23 - 23:39:33
    The product page for the Professional Board is still on-line (https://www.parallax.com/product/32111) and has links to the Product Guide and Schematic. As Rayman mentioned, you can use the Propeller tool to program in Spin under Windows or you can use the Propeller IDE under Windows, MacOS, or Linux to program in Spin or the Simple IDE to program using C or C++ or BlocklyProp to use a graphical web-based programming tool ... again all cross platform. For those options, look at https://learn.parallax.com. For downloads, look here: https://www.parallax.com/downloads/propeller-p8x32a-software
  • BarryS,
    The Propeller Professional Development Board (PPDB) is very nice and powerful but unlike most other Propeller boards nothing is wired to the chip.
    Most of the Propeller Tool demo programs were written for the Demo board so here is the schematic for it.
    https://www.parallax.com/downloads/propeller-demo-board-schematic
    Propeller C and BlockyProp use the Activity board which doesn't have video connections but has an ADC and an XBee socket.
    https://www.parallax.com/sites/default/files/downloads/32912-Propeller-Activity-Board-WX-Guide-v2.1.pdf
    https://www.parallax.com/sites/default/files/downloads/32912-Propeller-Activity-Board-WX-Schematic-Rev-B-and-C.pdf
    Propeller C
    http://learn.parallax.com/tutorials/propeller-c
    BlockyProp
    http://learn.parallax.com/tutorials/language/blocklyprop
  • Thanks for all the help. As soon as I receive the board i'll let you all know.
    I'm used to the BoeBot stuff, but have been wondering about the Propeller
    chip. I'll get back to all of you when ready with the board.
    Barry
    ... and I can use BlockyProp with it.. Now that is interesting.
    Oh all this stuff about StampWorks is about programming??
    Here I was looking for software... is there a Stampworks for
    the Propeller?
  • The https://learn.parallax.com stuff is the equivalent to the StampWorks stuff for the Propeller. You can still download the StampWorks Manual here: https://www.parallax.com/sites/default/files/downloads/27297-StampWorks-Manual-v2.1.pdf
    There's a similar kit for the Flip Module with a somewhat different set of experiments here: https://www.parallax.com/product/32023
    Browse through the Parallax website to get a sense of where Parallax is in terms of curriculum and supporting products.
  • welcome to the forum @BarryS,
    you are lucky that you got a PPDB, Parallax does not build them anymore and those things are awesome. Mine is my most used development board.
    Like @Genetix, mentioned nothing is wired to any fixed location so you can use all pins like you want and just connect those things you need.
    But you have a nice big breadboard and lots of things to play with.
    Enjoy!
    I am just another Code Monkey.
    A determined coder can write COBOL programs in any language. -- Author unknown.
    Press any key to continue, any other key to quit
    The key words "MUST", "MUST NOT", "REQUIRED", "SHALL", "SHALL NOT", "SHOULD", "SHOULD NOT", "RECOMMENDED", "MAY", and "OPTIONAL" in this post are to be interpreted as described in RFC 2119.
  • Thanks Mike! I was an engineering tech before I retired. I had a crazy thought. From what I can see, it looks like the propeller processor is in a socket? I was wondering if there was a way via a plugin interconnect piggyback board to have a basic stamp processor use the same board? It would be interesting to use it for basic stamp or propeller since these boards are so rare now. Plus the biggest reason I like these board is it gives you a lot of breadboard space to build circuits. Then again the easier option is go the Arduino piggyback route and be able to plugin what ever option circuitry you need. But Arduino does not have a propeller like processor! Hey Parallax, build piggyback option boards for your propeller robots, now that could be a whole new market for Parallax!
  • The BASIC Stamp series microcontrollers use a 6-12v power supply and a 5v supply to regulate the I/O logic, which operates on a 5v logic level. As opposed to the Propeller, which uses 3.3v for everything, many of the electronics on the board may be tailored for the 3.3v logic. As you said, It would be interesting to see, and I would be quite impressed to see it!
    Windows 10 Home:
    Propeller Tool 1.3.2, BASIC Stamp Editor 2.5.4, Javelin Stamp IDE x.x.x, Arduino IDE, PST
    Hardware:
    BASIC Stamp Board of Education, Propeller Board of Education, Propeller Project Board, Propeller Mini
  • PublisonPublison Posts: 10,925
    edited 2019-03-24 - 20:41:18
    BarryS wrote: »
    The development board for BS2 series was different:
    https://www.mouser.com/ds/2/321/28138-PDB-v2.0-180132.pdf
    Not pin compatible with the Propeller chip.
    Infernal Machine
  • Ah but how about making an adapter that could make the pins go to their respective pins to match. Would be interesting to see if it was possible...
  • Also I was playing around with the Propscope and saw the plugins option... anybody know what that is about?
