LED Strips Help! on P8X32A-Q44 with APA102 LEDs
Peavey5150Peavey5150 Posts: 20
edited 2019-02-27 - 23:33:42 in General Discussion
Can I run LED RGB Strip - Addressable (APA102)
On the P8X32A-Q44 or any parallax micro controllers?
I want to test with the propeller Flip micro controller.
I also have propeller activity board WX.
Will any of these work for the APA102 strips?
If so...
What Library's do I need?
  • Peavey5150 wrote: »
    If so...
    Beau Schwabe created an APA102 RGB LED Demo... Attached is a ZIP of the project, that can be used as a start on your own code.
    dgately
    Livermore, CA (50 miles SE of San Francisco)
  • Beau Schwabe created an APA102 RGB LED Demo... Attached is a ZIP of the project, that can be used as a start on your own code.
    dgately
    Thanks for the help
    Is there any code for Propeller C?
  • dgatelydgately Posts: 1,088
    edited 2019-02-28 - 05:50:37
    I had converted the project with spin2cpp a while ago, it compiles, but I have not run this in a while... Give it a try!
    And, I've just attached JonnyMac's APA102 demo project (also converts to C with spin2cpp)...
  • Buck RogersBuck Rogers Posts: 1,482
    edited 2019-02-28 - 20:25:39
    That's still amazing.
  • Since the APA102C is similar to SPI, you may be able to use anything. I use the Propeller. I've attached the latest version of my APA102C object which has been used in the movie Zoe (animation code by my friend, Matt Hawkins) and in the TV show Black Lighting (Thunder's belt buckle; animation code by me). That is to say that I think you can trust it. :smiley:
    Jon McPhalen
    Hollywood, CA
    It's Jon or JonnyMac -- please do not call me Jonny.
