Using 64GB SDHC/SDXC "exFAT" cards with the P2 and TAQOZ
Peter JakackiPeter Jakacki Posts: 8,787
edited 2019-02-20 - 12:46:00 in Propeller 2
I finally got around to picking up a Sandisk 64GB card today. After I ran a quick scan of active sectors it didn't report anything after sector $1..0200 but it would have taken a few hours maybe although it got through well over a 1GB in about 10 minutes just finding active sectors and then dumping the first 16 bytes for reference.
Anyway, I was really more interested in formatting these cards to FAT32 using my new disk utilities. So it works really well and it's fast. I just typed "0 FORMAT" to select automatic cluster sizing which in this case would be the maximum 64kB clusters.
Here's what my PC saw the card as:
Remounting the card after checking and loading files from the PC then backing up the system to a file which is then renamed and the system rebooted.
TAQOZ# .DISK ---  CARD: SANDISK   SD SC64G REV$80 #35190404 DATE:2018/10
                   *** OCR ***
    VALUE........................... $C0FF_8000
    RANGE........................... 2.7V to 3.6V
                   *** CSD ***
    CARD TYPE....................... SDHC
    LATENCY......................... 1ms+1400 clocks
    SPEED........................... 50Mbps
    CLASSES......................... 010110110101
    BLKLEN.......................... 512
    SIZE............................ 62,367MB
                 *** SPEEDS ***
    SECTOR.......................... 660us,333us,334us,335us,333us,334us,335us,333us,
    BLOCKS.......................... 2,519kB/s @240MHz
                   *** MBR ***
    PARTITION....................... 0 00 INACTIVE
    FILE SYSTEM..................... FAT32 LBA
    CHS START....................... 1023,254,63
    CHS END......................... 0,0,0
    FIRST SECTOR.................... $0000_8000
    TOTAL SECTORS................... 124,702,720 = 63,847MB
00170: 0000_0000 0000_0000 0000_0000 0000_0000     '................'
                  *** FAT32 ***
    OEM............................. TAQOZ P2
    Byte/Sect....................... 512
    Sect/Clust...................... 128 = 64kB
    FATs............................ 2
    Media........................... F8
    Sect/Track...................... $003F
    Heads........................... $00FF
    Hidden Sectors.................. 32,768 = 16MB
    Sect/Part....................... 124,702,720 = 63,847MB
    Sect/FAT........................ 7,675 = 3MB
    Flags........................... 0
    Ver............................. 00 00
    ROOT Cluster.................... $0000_0002 SECTOR: $0000_BC16
    INFO Sector..................... $0001 = $0000_8001
    Backup Sector................... $0006 = $0000_8006
    res............................. 00 00 00 00 00 00 00 00 00 00 00 00
    Drive#.......................... 128
    Ext sig......................... $29 OK!
    Part Serial#.................... $50AD_0021 #1353515041
    Volume Name..................... P2 CARD    FAT32    ok
TAQOZ# DIR ---
  0: ROOTDIR      08
  1: P2      .ROM 20 $0000_BC96   2019-02-24 08:21         65,536 /        65,536   X...P2D2F   ........
  2: _BOOT_P2.BIN 20 $0000_BD16   2019-02-24 08:21         65,536 /        65,536   X...P2D2F   ........
  3: P2D2A   .BMP 20 $0000_BD96   2018-12-24 14:26        308,346 /       327,680   BMz.......z...l.....
  4: TIGER   .BMP 20 $0000_C016   2018-12-24 14:23        308,346 /       327,680   BMz.......z...l.....
  5: BIRD    .BMP 20 $0000_C296   2018-12-24 06:54        308,346 /       327,680   BMz.......z...l.....
  6: BUZZ    .BMP 20 $0000_C516   2018-11-24 01:53        308,346 /       327,680   BMz.......z...l.....
  7: FIRE    .BMP 20 $0000_C796   2018-11-24 23:51        308,346 /       327,680   BMz.......z...l.....
  8: SPIDEY  .BMP 20 $0000_CA16   2018-10-24 04:24        308,346 /       327,680   BMz.......z...l.....
  9: MCQUEEN .BMP 20 $0000_CC96   2018-10-24 04:19        308,346 /       327,680   BMz.......z...l.....
 10: EYEGOD  .BMP 20 $0000_CF16   2018-10-24 04:17        308,346 /       327,680   BMz.......z...l.....
 11: SUNSET  .BMP 20 $0000_D196   2018-10-24 04:13        308,346 /       327,680   BMz.......z...l.....
 12: FACE    .BMP 20 $0000_D416   2018-10-24 04:03        308,346 /       327,680   BMz.......z...l.....
 13: DRAGON  .BMP 20 $0000_D696   2018-10-24 01:21        308,346 /       327,680   BMz.......z...l.....
 14: LMMS    .BMP 20 $0000_D916   2018-10-24 01:01        308,280 /       327,680   BM8.......6...(.....
 15: FISH2   .VT  20 $0000_DB96   2017-11-24 15:08        211,945 /       262,144   .[H.[J..[1;0H
 16: ASCIIART.TXT 20 $0000_DD96   2017-11-24 15:05         55,148 /        65,536   From dondd@hpmwtd.HP
 17: MIDENG  .TXT 20 $0000_DE16   2017-11-24 14:11      1,248,077 /     1,310,720   ...The Project Guten
 18: VULGAR  .TXT 20 $0000_E816   2017-11-24 13:56        511,916 /       524,288   ...Project Gutenberg
 19: ROUGES  .TXT 20 $0000_EC16   2017-11-24 13:51        219,885 /       262,144   ...The Project Guten
 20: LEXICON .TXT 20 $0000_EE16   2017-11-24 13:48        988,130 /     1,048,576   ...The Project Guten
 21: WARWORLD.TXT 20 $0000_F616   2017-11-24 13:42        365,413 /       393,216   ...The Project Guten
 22: WEBSTERS.TXT 20 $0000_F916   2017-11-24 12:59     28,956,348 /    28,966,912   ...The Project Guten
 23: ILIAD   .TXT 20 $0001_D616   2017-11-24 12:55      1,201,891 /     1,245,184   ...The Project Guten
 24: PRIDE   .TXT 20 $0001_DF96   2017-11-24 12:54        726,223 /       786,432   ...The Project Guten
 25: KJV     .TXT 20 $0001_E596   2017-08-24 12:28      5,504,282 /     5,505,024        _______________
 26: WARPEACE.TXT 20 $0002_0F96   2015-08-24 07:27      3,226,652 /     3,276,800   The Project Gutenber
 27: LOVE    .WAV 20 $0002_2896   2015-02-24 08:06     14,630,692 /    14,680,064   RIFF.?..WAVEfmt ....
 28: POPCORN .WAV 20 $0002_9896   2012-11-24 13:26      3,242,394 /     3,276,800   RIFF.y1.WAVEfmt ....
 29: P2      .LZ4 20 $0002_B196   2019-02-24 14:03         18,057 /        65,536   ."M.d@.vF...0X...P2D  ok
TAQOZ#  ---  ok
TAQOZ#  ---  ok
TAQOZ# BACKUP _BOOT_P2.BIN SUCCESS! ---  ok
TAQOZ#  ---  ok
TAQOZ# RW ---  ok
TAQOZ# RENAME _BOOT_P2.BIN _BOOT_P2.BIX ---  ok
TAQOZ#  ---  ok
TAQOZ#  ---  ok
TAQOZ# FLUSH ---  ok
TAQOZ#  ---  ok
TAQOZ# REBOOT ---�
  Parallax P2  *TAQOZ* Extensible Firmware  V2.0 'CHIP' 240MHz 190212-1700
TAQOZ#
Tachyon Forth - compact, fast, forthwright and interactive
P2 --- The LOT --- TAQOZ INTRO & LINKS --- P2 SHORTFORM DATASHEET --- TAQOZ RELOADED - 64kB binary with room to spare
P1 --- Latest Tachyon with EASYFILE --- Tachyon Forth News Blog --- More
paypal.png PayPal me
Brisbane, Australia
1614 x 976 - 141K
