Shop Learn
regarding raspberry pi and DHB 10 connection — Parallax Forums
Can we use raspberry pi GPIO pins (don't want to control with serial pins ie; Rx and Tx pins)to control channel 1 and channel 2 of DHB 10 motor controller board? is it possible?
actually I am trying like this:
CH 1: white pin to GPIO 17
black pin to ground
Red pin with no connection
CH 2: white pin to GPIO 18
black pin to ground
but motors are not running .
code:
import time
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
GPIO.setup(17,GPIO.OUT)
GPIO.setup(18,GPIO.OUT)
print('Starting motor sequence!')
while True:
try:
GPIO.output(17, True)
GPIO.output(18, False)
time.sleep(3)
GPIO.output(17, False)
GPIO.output(18, True)
time.sleep(3)
except(KeyboardInterrupt):
print('Finishing up!')
quit()
