Welcome to the Parallax Discussion Forums, sign-up to participate.
#include <time.h> #include <unistd.h> #include <stdio.h> // Recommended over iostream for saving space #include <stdlib.h> #include <propeller.h> // Propeller-specific functions #include <i2c.h> #include "MAX11617.hpp" #define BYTE_TO_BINARY_PATTERN "%c%c%c%c%c%c%c%c" #define BYTE_TO_BINARY(byte) \ (byte & 0x80 ? '1' : '0'), \ (byte & 0x40 ? '1' : '0'), \ (byte & 0x20 ? '1' : '0'), \ (byte & 0x10 ? '1' : '0'), \ (byte & 0x08 ? '1' : '0'), \ (byte & 0x04 ? '1' : '0'), \ (byte & 0x02 ? '1' : '0'), \ (byte & 0x01 ? '1' : '0') int main(){ for (int i=0;i<5;i++){ printf("Waiting... %d\n", i); sleep(1); } printf("Setting up i2c.\n"); I2C_COGDRIVER* i2cDriver = (I2C_COGDRIVER*)malloc(sizeof(I2C_COGDRIVER)); I2C *i2c_dev = i2cOpen(i2cDriver, 28, 29, 40000); if (!i2c_dev){ printf("Failed to open i2c.\n"); free(i2cDriver); return 1; } uint8_t setup[] = { (uint8_t)MAX11617::Setup(), (uint8_t)MAX11617::Config( MAX11617::ConfigBits::UptoChannel, MAX11617::ConfigBits::MAX ), MAX11617::HSMode }; int setuperr = i2cWrite(i2c_dev, MAX11617::Addr, setup, 3, 1); if(!setuperr){ printf("Could not send setup/config.\n"); i2cClose(i2c_dev); return 1; } printf("Setup Err: %d\n"); printf("Switching to HS Mode.\n"); i2cClose(i2c_dev); i2c_dev = NULL; i2c_dev = i2cOpen(i2cDriver, 28, 29, 3400000); if (!i2c_dev){ printf("Failed to open i2c in HS Mode.\n"); free(i2cDriver); return 1; } printf("Reading Data:\n"); uint8_t buff[2*12]; for (int i=0; i < 2*12; i++) buff[i] = 0; while (int err = i2cRead(i2c_dev, MAX11617::Addr, buff, 2*12, 1)){ printf("Err: %d\n", err); for (int i=0; i < 2*12; i+=2){ printf("%d: %d - %d - " BYTE_TO_BINARY_PATTERN " - " BYTE_TO_BINARY_PATTERN "\n", (i/2), buff[i], buff[i+1], BYTE_TO_BINARY(buff[i]), BYTE_TO_BINARY(buff[i+1])); buff[i] = buff[i+1] = 0; } sleep(1); } i2cClose(i2c_dev); free(i2cDriver); return 0; }
#pragma once #ifndef MAX11617_H #define MAX11617_H namespace MAX11617 { //Setup Bits namespace SetupBits { namespace Clock { const bool External = true; const bool Internal = false; } namespace Polar { const bool Bipolar = true; const bool Unipolar = false; } namespace Reset { const bool NoAction = true; const bool ResetConfig = false; } enum RefVoltage { VDD = 0b00000000, //VDD Voltage Reference, Ref pin - analog input. EXT_REF = 0b00100000, //External Reference, Ref pin - reference input. INT_OFF = 0b01000000, //Internal Reference, Ref pin - analog input, internal reference state - always off. INT_ON = 0b01010000, //Internal Reference, Ref pin - analog input, internal reference state - always on. INT_OFF_REFOUT = 0b01100000, //Internal Reference, Ref pin - reference out, internal reference state - always off. INT_ON_REFOUT = 0b01110000 //Internal Reference, Ref pin - reference out, internal reference state - always on. }; } //config Bits namespace ConfigBits { namespace SGL_DIF { const bool SingleEnded = true; const bool Differential = false; } enum ChannelSelect { AIN0 = 0b00000000, AIN1 = 0b00000010, AIN2 = 0b00000100, AIN3 = 0b00000110, AIN4 = 0b00001000, AIN5 = 0b00001010, AIN6 = 0b00001100, AIN7 = 0b00001110, AIN8 = 0b00010000, AIN9 = 0b00010010, AIN10 = 0b00010100, AIN11 = 0b00010110, MAX = 0b00011110 }; enum ScanConfig { UptoChannel = 0b00000000, Convert8x = 0b00100000, UpperHalf = 0b01000000, ConvertSelected = 0b01100000 }; } const unsigned char Addr = 0b01101000; inline unsigned char Address(bool rw) { return (char)(Addr | rw); } const unsigned char HSMode = 0b00001000; inline unsigned char Setup_Raw( bool sel0 = false, bool sel1 = false, bool sel2 = false, bool clk = false, bool bip_uni = false, bool rst = true ) { return (unsigned char)(1 << 7 | sel2 << 6 | sel1 << 5 | sel0 << 4 | clk << 3 | bip_uni << 2 | rst << 1 | 0); } inline unsigned char Config_Raw( bool scan0 = false, bool scan1 = false, bool cs0 = false, bool cs1 = false, bool cs2 = false, bool cs3 = false, bool sgl_dif = true ) { return (unsigned char)(0 << 7 | scan1 << 6 | scan0 << 5 | cs3 << 4 | cs2 << 3 | cs1 << 2 | cs0 << 1 | sgl_dif); } inline unsigned char Setup( SetupBits::RefVoltage sel = SetupBits::VDD, bool clk = SetupBits::Clock::Internal, bool bip_uni = SetupBits::Polar::Unipolar, bool rst = SetupBits::Reset::NoAction ) { return (unsigned char)(1 << 7 | sel | clk << 3 | bip_uni << 2 | rst << 1 | 0); } inline unsigned char Config( ConfigBits::ScanConfig scan = ConfigBits::UptoChannel, ConfigBits::ChannelSelect channel = ConfigBits::AIN0 , bool sgl_dif = ConfigBits::SGL_DIF::SingleEnded ) { return (unsigned char)(0 << 7 | scan | channel | sgl_dif); } } #endif
The chip offers two clocking modes, one using an internal oscillator and clock stretch, and one using external clocking via the scl signal, which does not use clock stretch. The mode is set by the "clk" bit in the setup register. You might try that.
It is a versatile ADC with lots of modes. BTW, it is 12 bit, not 16 bit.
Getting 0 on both initErr and err, so it should be working but doesnt seem to be getting any data...
Updated code:
Edit: Crap, forgot pullups...
Edit2: Yea, im getting nothing... initErr keeps giving me -1...
It detects the 24LC128 that i have but not the MAX11617...
Im thinking i fried both chips when soldering them to a dip board...
Might have been my shitty soldering without flux...
Broke a pin off of the second chip by accident but still works regardless.
