Latest version of PNut?
My current copy of PNut.exe is from over five years ago. Where can I find the latest version?
  • You may not want the absolute newest version of PNut because that might be for the Rev B silicon. You need the version that corresponds to the Rev A silicon unless you're using an FPGA image for Rev B.
    I'd also like to know where the FPGA image is that matches the Rev A silicon. Is it the most recent image in the FPGA thread? It should probably be marked to indicate that it matches Rev A before more updates are posted for Rev B.
  • jmgjmg Posts: 13,346
    David Betz wrote: »
    No Rev B FPGA has been released, and I'd expect that to be clearly marked.
    Any assembler needs to be able to generate both Rev A and Rev B binaries, there was talk of a variant switch in pnut, but I think in the end it managed to be (mostly?) super-set compatible ?
    There were I think 2 new opcodes, for Chip's new scope ADC modes, so maybe a variant switch would help those generate errors on rev A ?
    Likewise for any expanded opcodes, any Rev A miss-use should generate an error (in case someone pastes in Rev B ASM )
  • Dave HeinDave Hein Posts: 5,898
    edited 2018-12-03 - 21:19:31
    The latest version of PNut is in the zipfile at https://forums.parallax.com/discussion/162298/prop2-fpga-files-updated-2-june-2018-final-version-32i/p1 . This is version 32i, and was posted in June before all the Rev B stuff was discussed. The previous zipfile contains version 32b, which is the one I use. I never updated to 32i, and I'm not sure why 32c through 32h were skipped.
  • I think 32c through 32h were iterations of the ROM that Peter and Cluso were working on
    32i is the current one
  • 32i matches final silicon and extended the support for more labels - a problem we ran into when compiling v32i ROM code.
    My Prop boards: P8XBlade2, RamBlade, CpuBlade, TriBlade
    Prop OS (also see Sphinx, PropDos, PropCmd, Spinix)
    Website: www.clusos.com
    Prop Tools (Index) , Emulators (Index) , ZiCog (Z80)
  • Instead of PNut you could also use Dave Hein's p2asm or my fastspin. Both are designed to have a simple command line interface for easier integration with external tools (like IDEs).
