Propeller manual pasm division
I am having issues with this code example. I cannot get the remainder and' ing and shifting as Dave at parallax advised. If I divide an even number all is good. An odd number does not work and I get gobbelygook.
Here is their code: page 380 of the propeller manual
' Divide x[31..0] by y[15..0] (y[16] must be 0)
' on exit, quotient is in x[15..0] and remainder is in x[31..16]
divide shl y,#15 'get divisor into y[30..15]
mov t,#16 'ready for 16 quotient bits
:loop cmpsub x,y wc 'y =< x? Subtract it, quotient bit in c
rcl x,#1 'rotate c into quotient, shift dividend
djnz t,#:loop 'loop until done
divide_ret ret 'quotient in x[15..0],
'remainder in x[31..16]
“Light thinks it travels faster than anything but it is wrong. No matter how fast light travels, it finds the darkness has always got there first, and is waiting for it.”
“You only live twice:
Once when you are born
And once when you look death in the face”
  • Search for my faster spin Interpreter. It has an optimised PASM divide IIRC. My signature may have a link too.
    My Prop boards: P8XBlade2, RamBlade, CpuBlade, TriBlade
    Prop OS (also see Sphinx, PropDos, PropCmd, Spinix)
    Website: www.clusos.com
    Prop Tools (Index) , Emulators (Index) , ZiCog (Z80)
  • Clusco,
    It looks like the links in your signature are broken (maybe because of the n-th forum upgrade?).
    Anyway, as an example the Prop Tools (Index) link is currently:
    http://forums.parallax.com/showthread.php?t=106790
    ...and might need to be instead:
    https://forums.parallax.com/discussion/106790
    Hope you take this as a friendly observation. Always have valued your code, comments, and commitment to the Prop!
    -joe
  • to octetta I will look at what you sent. for Cluso99 broken links.
    thanks to both
  • The divide routine is fine, but you make a mess with the variablepointers and the wrlong parameters.
    Here is a modified version that works for me on a Quickstartboard:
    CON
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000          'QUICKSTART 80 MHZ  NORMAL CRYSTAL
    var
       long dividend         'VARIABLE IN THE PAR ADDRESS TO BE PASSED
       long divisor
       long quotient
       long remainder
    obj
      pst : "parallax serial terminal"
    pub main
       dividend := 21
       divisor := 2
       pst.start(115200)
       waitcnt(clkfreq*5 + cnt) 'hold five sec to open the
                                'serial terminal and enable it
       cognew(@asm,@dividend)   'start cog at the first variable address
       waitcnt(clkfreq + cnt)   'give top object time to catch up to pasm
       pst.str(string("quotient:"))
       pst.dec(quotient)
       pst.newline
       pst.str(string("remainder:"))
       pst.dec(remainder)
       pst.newline
    dat
    asm       org
              mov tempvar, par      'get the par address into the temporary variable
              rdlong x, tempvar     'read the value into the dividend
              add tempvar, #4       'move over to the next long to get the divisor variable
              rdlong y, tempvar     'read the value of the divisor into the variable
              add tempvar, #4       'move over to the next long to get the quotient address
    '  quotient in x[15..0],  ;return if used as a subroutine
    '  remainder in x[31..16]
              mov    quotientvar,x
              and    quotientvar,andvar2    'isolate lower 16 bits
              wrlong quotientvar,tempvar    'write into Spinvar 'quotient'
              mov    remaindervar,x
              shr    remaindervar, #16      'isolate higher 16 bits
              add    tempvar,#4             'incr pointer to remainder address
              wrlong remaindervar,tempvar   'write into Spinvar 'remainder'
    andvar2       long $ffff
    tempvar       res 1
    x             res 1
    y             res 1
    quotientvar   res 1
    remaindervar  res 1
    t             res 1
    Andy
  • Thanks for the broken links feedback. I'll fix as soon as I get time on a real computer.
  • No worries. Seems this is an endemic problem, so you're not the only one.
    Any hope the forum moderators could to a global search and replace for these "showthread.php?t=" things?
    I'm not even sure who to reach out for matters like that...
  • octetta wrote: »
    Don't bother wasting you time.
  • PublisonPublison Posts: 10,964
    edited 2018-11-26 - 21:36:15
    Unfortunately, the moderators can not perform things like that. Only webmaster@parallax.com can do that.
    Believe me, I would love to have that capability because I HATE broken links.
    Infernal Machine
  • I will try this tonight. I have been writing a tutorial and thank y'all a lot.
    I will post a version of it soon.
  • Hey guys, I have been researching the pasm stuff in the forums. The broken links are too numerous to count. I have mentioned this to parallax, but I don't think that they will work on it. They have changed the website too many times and the links are not a priority.
  • Works great. Thanks for the help.
