Need Help with Balancing Robot
amalfiCoast
in Robotics
I'm trying to develop a balancing robot but can't get it properly tuned. I'm using a complementary filter to get angles. My controller algorithm as well as my motor controller code is below. I'm using the Pololu VNH5019 motor controller and a Propeller Activity Board with Parallax gyroscope and accelerometer modules. Maybe someone who has successfully built a balancing robot could post their code. Thanks.
//PI with Rate Feedback float Error=theta*180/PI; float Error_int=Error_int+Ts*Error; float servo=kp*Error+ki*Error_int+kd*gx*180/PI; // Add PWM control for motors if(servo<0){ //Motor 1 high(0); low(1); pwm_set(2,0,-servo+15.); // when pwmstart = 100, set these to 1.8 //Motor 2 high(3); low(4); pwm_set(5,1,-servo+18.); } else if(servo>0){ //Motor 1 high(1); low(0); pwm_set(2,0,servo+15.); //Motor 2 high(4); low(3); pwm_set(5,1,servo+18); } } }
