Investigation of the carry result of MOVS and friends
Wuerfel_21
in Propeller 1
Raise your hand if you've ever thought about what MOVS,MOVD and MOVI write to the carry flag!
Nobody? meh.
The Propeller Manual has the incredibly helpful description "---", yet the concise truth table shows the carry sometimes getting set. However, I cannot deduce it's meaning from that. I've also looked at GEAR's code, but it's author doesn't have any idea, either. So i had to go deeper: The P1V verilog code. There, I found the truth: MOVS, MOVD and MOVI, as one would expect, share a lot of logic with JMPRET. For these four instructions, the carry generation logic selects the carry output from the adder, which is configured to calculate D-S. Thus, the carry is simply that: unsigned D<S
I've run some tests, which seem to support this claim.
So now we know what MOVS, MOVD and MOVI do. However, what was that about JMPRET? JMPRET's manual entry states that:
Nobody? meh.
According to the Verilog AND my tests, this is very very wrong. Parallax should consider updating the manual to state the carry results of the four instructions I talked about and to change the remark on JMPRET toThe C flag is set (1) unless PC+1 equals 0; very unlikely since it would require the JMPRET to be executed from the top of cog RAM
($1FF; special purpose register VSCL).
The Z flag is cleared (0) unless PC+1 equals 0; very unlikely since it would require the JMPRET to be executed from the top of cog RAM
http://forums.parallax.com/discussion/156347/improved-gear-emulator
Original thread in the first post.
